« 1 2 3 (4)
Re: suggestions l20b or a15
Keep it stock as is. Will be more than enough compared to a15. Engines already built D
Posted on: 2012/9/1 14:07
Not too shy to talk
From Perth WA
what is the easiest way to separate boot rubber crimp? Gotta rare spares boot seal and looks like you have to separate crimp to get it on, then put it on and use pliers or something to crimp back on. Anyway its gonna take me ages the way im doing it, screwdriver all the way down it.
Posted on: 2012/9/2 10:39
yep stock is good but they are so cheap might as well build a peppy one on the side Z20E rods and Z22E slugs cost bugger all not to mention the flooded classifieds of go fast bits for them.
The only nissan donk with 5 different heads for all uses.
eg.
L series non crossflow stock 8v can go to:
Ka24e 12 valve SOHC hydro lifters
Ka24DE 16 vave DOHC solid lifters
Z18ET turbo 8v solid lifters
NA20 crossflow roller rocker 8v
Posted on: 2012/9/2 11:44
From south australia
I agree with what you guys are saying the ca18 is an ugly motor. But its also reasonbly modern compared to the l series donk. if you wanted to beable to pop the bonnet and have a good looking motor for the car then may as well stay a series. they can look quite good and tidy. As previously stated though its all really down to personal preferance and what you want from your car.
Posted on: 2012/9/2 12:23
The meaning of life is not in the fridge..
Its in the shed....
From Sydney NSW
there might be a bit more to it than personal preference, it would take a lot of commitment doing a ca18 swap. Just about everything needs to be changed; fuel, diff, wiring and cables, brakes, suspension, crossmembers and mounts, hydraulic lines, it goes on. I would like to see what some folks have spend on their conversions (or perhaps they don't want to know themselves)
Posted on: 2012/9/2 15:19
I know what ur saying but even with the l motor ul still need 2 change half of that stuff like suspension and brakes cos if u make it go it has to be able to stop. Im not trying to say its cheaper either. Its just my thoughts that if ur gonna go through half of that anyway why not go the whole way and have a newer motor. Plus if u really didnt wanna do wiring im sure u could carb it just to be different. But theres lots of reasons for all the motors that every1 could argue all day so it is really preference. And of course money will be a factor.
Posted on: 2012/9/2 17:48
Its in the shed....
From Geelong, Vic
elemental_funk, i spent $1500 when i first did the CA18DE+t converstion into my 1200 sedan and i had to piece together all the turbo stuff and flywheel and clutch from many different people so that made it cost more. i did already have the gearbox and radiator in there from the L series that was in before it. also had suspention and brakes sorted but i dont really count that as part of the conversion cost as everyone should be upgrading their brakes in a 1200, and the diff comes with power, you dont need to upgrade it but if you have a certain level of power you will probably start breaking them no matter what engine it is
in saying that though, i have since spent an extra say $3000+ to get it to the point where i want it, full forged rebuild, bigger turbo, better manifold, tune and so on.
I'd say CA is actually an easier conversion to do as far as mechanical stuff is concerned (in a 1200) given they are smaller. but in a 120y the larger size of the L series probably isnt an issue
i wouldnt go any of the bolt in crossmembers as i doubt any of them will really sit the engine in an awesome position, and making new mounts on the crossmember isnt really at all hard
a built turbo A series or L series would be pretty cool, a well made injection/turbo setup on an L series sitting in a 1200 (or 120y) engine bay would look quite nice in my opinion
and I'd agree with you that money, or skill and equiptment to offset the need to spend money, is a large part of what engine goes into most cars
Posted on: 2012/9/3 1:43
From Everywhere, mostly Melb/Geelong/Ballarat
Can I second what Pigdog said about the bolt-in crossmembers?
The first time Nick told me that I thought he was full of s*it. Since then I have used bolt in x-members for two engine swaps and am unhappy with both of them. The engines just don't sit where I want.
And, again as Pigdog said, efi L-series in a 1200 is teh sex.
Posted on: 2012/9/3 6:30
« 1 2 3 (4)
