Ca18DET exhaust manifold choices
Anyone run the cheap ebay manis?
http://www.ebay.com.au/itm/NISSAN-SIL ... ories&hash=item3a71024704
supposedly they crack been thin SS and with no web supports
Any other options or should I stick to stock manifold?
Posted on: 2012/10/3 4:02
Re: Ca18DET exhaust manifold choices
From Adelaide
they would be fine in my opition but i have found that most of the time stock has had enough time and research put in it to run standard turbos to their max anyways.
Posted on: 2012/10/3 4:12
HY_FLO MOTORSPORT - designing a new wave in motorsport
hy.flo912@gmail.com
0411 725 347
www.facebook.com/HyFloMotorsport
FOLLOW ME
From Sydney NSW
I have one here brand new, never used, for reasonably less than the ebay price if you want it. This same brand but bottom mount: http://www.ebay.com.au/itm/NEW-NISSAN ... ories&hash=item5193b07aa9
The ports look like they were done by a monkey but the welds are good and nice thick tube. Warranties speak for themselves.
Posted on: 2012/10/3 7:45
From Sydney NSW
I should say it is for a T2 series not T3
Posted on: 2012/10/3 7:48
I'd use the stock one
Posted on: 2012/10/3 7:57
From Melbourne, Australia
thought you were doing a DE?
i say stock, ceramic coating it would be nice though, a lot more design goes in to them than these aftermarket ones, unless you want big power there is no point upgrading especially if going for a cheap one
Posted on: 2012/10/3 8:13
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney
What ever you do don't get Maddat to make you one, unless you want to sent it back a few times to fix it so it properly fits, if only they trail fitted the stuf before they send it out.. I guess everything is of a jig there from 20 years ago
My 2cents
Posted on: 2012/10/3 12:56
Was going DE but gave up when weighing up the cost of billet cams, bigger valves, porting, custom TBs running on Brand ecu, springs, custom header, custom cam belt and some other things when a reasonably stock ca16det on nistune would be way gutsier with less effort. No cant fit an SRVE in a 1000 :(
Ca16de+T block can be bore to 84mm as some have done on the exa forums.
Problem with stock ex mani is its just too far back for the turbo with no room for dump pipe and bottom mount sits turbo too close to suspension wishbone and support shoulders so will most like have to make a custom log mani from scratch using butt welds.
Posted on: 2012/10/3 14:02
From Sydney, Australia
I may have something.
I made a steam pipe manifold and dump pipe that moves the turbo forwards 5 - 10 cms.
It was only used for short time as I swapped to stainless.
Will need custom oil/water lines, but with you doing ca16, you are already doing this.
Posted on: 2012/10/3 20:06
Can you put a pic up Chis? sounds interesting is it straight out, top mount or bottom? problem is the bottom mount hits suspension tower.
Posted on: 2012/10/4 1:12
