Browsing this Thread:
1 Anonymous Users
wiring loom, |
From sydney
i just finished the rebuild and wiring on my a12, the battery has charge, as far as i know everything is in the right spot
only problem is, i turn the key for the first start, and nothing, no dash or anything, any ideas or fault finding tips will be greatly appreciated, it is doing my head in!!
Posted on: 2012/10/15 11:50
Re: wiring loom, |
From south australia
I would start with the ignition barrel itself check thats working and its got power and earth. If its got nothing check its connected down the loom under dash. Could also be that the earth or positive from batt isnt attached at block or starter or whateva ur lookin at. I cant remember but surly they have a ignition fuse or main fuse somewhere check that. Think simple first before u pull out ur hair.
Posted on: 2012/10/15 16:22
The meaning of life is not in the fridge.. Its in the shed....
Re: wiring loom, |
Registered Users Contentmaster Usermaster
Quote: only problem is, i turn the key for the first start, and nothing, no dash or anything This is more than one cause for this problem. But the most common cause is solved by Battery Maintenance -- even if it is a new battery! Give it a try.
Posted on: 2012/10/15 20:47
Re: wiring loom, |
From sydney
Ok thanks, I will go over everything again, I did spray body deadened inside the car, is it possible I have covered a few terminals?? The starter definently has power to it but after that nothing
Posted on: 2012/10/15 23:14
Re: wiring loom, |
hahaha yea well i would look at ignition wires or barrel then.
Posted on: 2012/10/16 1:20
Re: wiring loom, |
From sydney
Ok will do, thanks, any other ideas pleas let me know
Posted on: 2012/10/16 2:19
Re: wiring loom, |
Quite a regular
From Mid North Coast N.S.W
I am in the process of partially rewiring a project from another manufacturer (so won't be mentioned on this forum) and have found most of my dramas being to faulty earths either through lack of sufficient bare-metal contact with terminals or simply because I un-did one and didn't re-attach it.
If your stumped then use a multi-meter (M-M) and trace power from the battery to ignition, starter motor as mentioned and fuse box. Then maybe check Earths for broken wires within the sleeves. A decent M-M will be able to send a signal through the wire. Sorry if this is obvious stuff...
Good luck.
Posted on: 2012/10/17 12:55
'72' B110 sdn '68' (allegedly) B110 sdn '72' 808 sdn '00' E50 ELGRAND '93' JZA80 Supra
Re: wiring loom, |
Fusible link maybe, or starter trigger wire. That doesn't explain lights though. That Sounds like main power feed maybe
Posted on: 2012/10/17 13:01
Re: wiring loom, |
From Geelong, Vic
are there fuses in the fuse box, are the wires to the ignition barrel connected?
pretty much as most other people have said, get a multimeter or test light and find where power is, then you should be able to find out where it isnt and should be
Posted on: 2012/10/18 0:16
