Browsing this Thread:   3 Anonymous Users
(1) 2 3 4 ... 10 »
EOI - Toyota T50 adaptor plates group buy cheaper than Dellows
Hello peeps this is a thread to see who is interested in a billet plate to adapt an A series Auto bellhousing to a T50 toyota 5 speed using an adapter plate thats cheaper than buying a Dellows kit.
The person in charge of the adaptor plate has asked me to gauge interest to see if its worthwhile to go ahead with such an option.
He has one he uses for his beast and its very successful and a budget fix to those looking for a 5 speed.
Although the T50 boxes were getting quite rare it seems the toyota corolla ke20,25,30,35,70 and others like celica owners are getting out of using this box as their corollas are mainly rusting to the ground or upgrading to later toyota cars which require less work to stay on the road. This is good news for us as we have the better looking cars albeit with no cheap 5 speed options.
Therefore many T50 are now coming up for sale and although Im not a great fan of the 3.5 first gear its still almost the same ratio as available from 56a and 60a 4 speed boxes but with slight improvement in first an overdrive 5 speed and much stronger box than the rare nissan A series 5 speeds.
The adaptor plate will need an auto bellhousing which are easily sourced, then machine a bearing into A series flywheel and the input shaft sits in there. get a clutch to suit (details will be revealed soon), drill a hole for the clutch cable and bend a strip of ally and screw it down to hold the clutch cable. You cut a slot for the clutch fork to go thru the bellhousing, and use the datto 56a clutch fork, job done. They are much cheaper than the dellows kit in the end by quite some marging Im just looking for those interested first.
Im putting my hand up for 2 please add your name after mine
D - 2 x adaptor plates
xx-
xx-
etc etc
it will look something like this
(pictured is the W series adaptor to Toyota 4age series donks which used to use the T series but cant handle boosted 4age power so they go for the W series which are now coming from china under license and made from ex-Toyota japan factory castings and machines as Toyota has moved on to sourcing from Aisin 6 speeds and their own better and stronger R154 series boxes)
his original prototypes was like this
http://datsun1200.com/modules/myalbum/photo.php?lid=6895
I wont be responsible for the group buy or receive any favours except a great savings over using a Dellows kit which is exactly what myself and others want surely?
Posted on: 2012/11/20 12:11
Edited by D on 2012/11/21 0:25:32
Re: EOIU Toyota T50 adaptor plates group buy cheaper than Dellows
Not too shy to talk
From Central coast, nsw
Hey. I'm keen. Can you pm me a round about price by any chance.
Cheers
Posted on: 2012/11/20 12:38
Re: EOI - Toyota T50 adaptor plates group buy cheaper than Dellows
Just an EOI atm
but Im cost could be around 150-250 each depending on thickness of steel or alloy plate depending which one is going to work out cheaper or preferred by peeps.
2 x D
1 x slow_1200
1 x Dion120Y
1 x Graham
Posted on: 2012/11/21 0:29
PLS put your name as above, copy & paste to update.
I will answer PMs but prefer you put it above
5 plates so far keep em coming
Posted on: 2012/11/21 0:33
From St. Louis, MO USA
2 x D
1 x slow_1200
1 x Dion120Y
1 x Graham
2 x pjz
In the US I now race with a custom T50 behind my A13. It is a Houseman Autosport close ratio, straight cut, dog ring gearbox T50 conversion where Houseman builds all of the parts. These are now becoming reasonable in price. Contact me if anyone is interested.
Peter
Posted on: 2012/11/21 1:05
Not too shy to talk
Ohk so not too much. Hopefully it doesn't take too long. A15 doesn't like sitting on 4000 doing 100ks.
Cheers
Posted on: 2012/11/21 1:31
2 x D
1 x slow_1200
1 x Dion120Y
1 x Graham
2 x pjz
Thats 7 so far looking good
I might if theres enough interest supply the person who will be in charge with a W series box also just in case peeps want to run the W series box because the t50 and w5x boxes have the same input shaft length but much stronger and bolt pattern is very close.
If you look at the first picture which is a 4age t series to w series its quite obvious it probably wouldnt hurt to have another option etc.
Posted on: 2012/11/21 3:12
Simon is one smart cookie. Will support the cause to help bring prices down.
2 x D
1 x slow_1200
1 x Dion120Y
1 x Graham
2 x pjz
1 x clyons8
Posted on: 2012/11/21 6:32
He is actually another Bright Cookie called Dale :)
2 x D
1 x slow_1200
1 x Dion120Y
1 x Graham
2 x pjz
1 x clyons8
lucky 8!
Posted on: 2012/11/21 6:59
From Adelaide
I'd be in for one to suit a W5x gearbox since I've got one of those sitting on the shed floor.
Posted on: 2012/11/21 7:00
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
(1) 2 3 4 ... 10 »
