« 1 (2)
Re: Racing at Philip Island in the 1200 (Video clip)
Quite a regular
cool, would be great fun!
Posted on: 2012/12/5 6:20
From Las Vegas USA
Simon,
First my wife the artist said very nice video.
Next I love the G-meters on the dasd, I.E. the fluid tilting in the reservoirs.
As for the oversteer, definitely playing catcha-car. Mine was doing the same thing and just for the hell of it I dropped the rears 1 psi, it settled it down just enough. Out of curiosity what is the toe set at and can you adjust the rebound on the rear shocks. A darty car is easy enough to deal with but it doesn't seem consistent ...........corner entrances seemed to be mixed bag........although it sounded like someone hit you up the arse on one of the bigger moments. For sure in the long sweepers you were having to wait.
Great video, great driving..............looks like fun track, Philip Island looks awesome..........in this years MotoGP final I was (as was everyone) blown away by Stoners huge two wheel drifts in the fast right hander..............having now seen it in-car, it's even more awesome.
Tom
Posted on: 2012/12/6 2:59
From Ballarat Victoria
Cheers Tom,
The reservoirs are a bit distracting in the video! Maybe i should put a couple of diagonal lines on them showing .5, 1 and 1.5 G!
I was running 2mm out at the front and 2mm in on the rear.
It doesnt have any noticable understeer, so i`ll go up in the front bar rate a bit to start with.
The other thing i have done since the last outing is drop the rear ride height(less rake angle). This is probably effecting the aero ballance a bit too.
I may try dropping rear pressures now too, thanks.
I was stuffing up my lines into a couple of corners consistantly. I`ll be better next time.
The rear brakes also need some love. I had the balance bar set all the way to the rear but still not enough rear brake.
Youre spot on, the Philip Island circuit is fantastic! The best in the country except for maybe Bathurst.
Cheers
Posted on: 2012/12/6 8:50
Edited by sikyne on 2012/12/6 9:51:22
VIC DYNO HIRE
Fab vid Simon.
What camera is that your using?
Posted on: 2012/12/6 8:54
Car free
I bought it from the Good Guys. Its a Contour Roam. They were on special for about $190. The roll cage mount kit was extra.
Very easy to use and download. The footage you have watched is on the lowest resolution.
Im very happy with it.
Posted on: 2012/12/6 9:02
VIC DYNO HIRE
From Nations Capital, Australia
Love it. Sounds great mate.
Posted on: 2012/12/6 9:47
From Las Vegas USA
I hear you on the brakes, I finally put the bigger wheel cylinders in my car to bring the brake balance back........same issue as you were having.....just before turning in you'd have to wait just a split second, car rotates much better.
I also played with the rake, albeit several years ago and ended up going back to the original set-up.
Tom
Posted on: 2012/12/7 2:30
From Townsville
do you have watts link on the rear to help hold it from walking but great video
Posted on: 2012/12/7 9:15
« 1 (2)
