(1) 2 3 4 »
Ca Plenum Questions.
From Goulburn NSW
Hi guys im looking at getting a custom plenum made by Arial from custom plenum creations in wollongong.I have noticed that my head has 8 ports(obviously),but the plenum only has 4 tubes(if u know what i mean).Will these 4 tubes cater for 2 ports per tube?
Posted on: 2012/12/17 5:36
Re: Ca Plenum Questions.
Yes, if the 4 tubes are oval and cover the 2 ports.
Posted on: 2012/12/17 5:56
From Adelaide
if they don't match properly you'll be going backwards in terms of flow.
Posted on: 2012/12/17 7:31
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Brisbane
if your aiming below 400hp i would keep the stock manifold. money would be better spent on ecu or cams
Posted on: 2012/12/17 7:35
From Goulburn NSW
Hi guys i dont have the original plenum or manifold,the motor didnt have it when i bought it.I have talked to Ariel and for $400 he will port the head to match the plenum.
Posted on: 2012/12/17 8:01
From Brisbane
like this one ?
sounds like you have it worked out :) Would love to do a custom port job on my head. Big valve/cams Max sized 8 ports, injector per port and single runners. +50 psi hahah
jpg  27022011133.jpg (111.80 KB)
13026_50cedf2c43245.jpg 1024X768 px
Posted on: 2012/12/17 8:49
From Sydney
I've got a few spare stock plenum s and intake manifolds for a ca if your interested.
Posted on: 2012/12/17 8:53
From Logan, QLD
If you want a different option, I have a complete stock manifold with sensors for $50 in qld
From Goulburn NSW
Thank fellas,ill give the standard plenum and manifold a miss.Im spending 40g on the build over 4-5 yrs so another few grand isnt going to matter to much.
Yeah oda thats the style.
Posted on: 2012/12/17 9:03
That custom one is old tech much better designs available now, look up some Cosworth dual plane inlets manifolds and even some audi race ones for ideas if you are going crazy.
The stock ones work very well and can take bigger TB / Airflow meters etc.
Posted on: 2012/12/17 11:42
(1) 2 3 4 »
