Wtb t25/28 inlet pipe
Hi I'm after a straight inlet pipe for a t25/28 turbo in 2.5 or 3 inch, so it's the bit that bolts to the front of turbo then connects to afm ect, I'm not after a stock one as I've got one just arter a straight out one I can make fit my setup
Cheers nick
Posted on: 2012/12/26 10:34
Car free
Re: Wtb t25/28 inlet pipe
I don't have one mate but make one to suit your application. Get the flange for front of turbo and a pipe and if needed tack it all up and get an engineering place to weld it all up. Suit your car and your application
Posted on: 2012/12/26 12:22
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
From Logan, QLD
I don't know if it works as well for ca's but on rb30et's I used to put the afm right before the throttle body, It gives better results incase of cooler pipes blowing off, did not seem to affect the fuel ratio's at all.
Posted on: 2012/12/26 20:14
I still need to find a flange 1200 project u got one? I'd make one for sure if I could get all the stuff
Posted on: 2012/12/26 22:26
Car free
Is it a two bolt front your after mate? I don't have one but if you hit any performance/turbo place online or even Maddat may be able to help. I can't help you out but welding it I may be able to help you
Posted on: 2012/12/27 0:44
From stinking hot cairns
Posted on: 2012/12/27 1:32
There you go. Also get a new actuator from them guys and oils lines if needed. Not a bad company.
Posted on: 2012/12/27 2:32
