(1) 2 3 »
Radiator Upgrades - Read the tech wiki looking for something in Australia or ebay
From Sydney, NSW
Hi just wondering if anyone has a good suggestion for a radiator upgrade I could buy in Australia or source from ebay?
I read about the B210 ac radiator. being in aus and having over 40 deg celcius days I'd love to find a bigger alternative..
Cheers,
Tom
Posted on: 2013/1/7 22:08
Re: Radiator Upgrades - Read the tech wiki looking for something in Australia or ebay
Heaps of options.
Use a Gemini one if you don't mind trimming the front rad hole or custom mounts.
The cool a series in 40deg easy.
N13 and n14 pulsar radiators also work well, especially if you get a twin core one.
I used all these in my a series and never had issues.
Just find one which fits in the space and hose inlet and outlet same sides
Posted on: 2013/1/7 23:55
That's a Sunny B310 radiator isn't it? (stock B110 on left)
B210 and B310 are good Radiator Upgrades since the mounting bolts fit on one side of the 1200.
The later Pulsar radiators are monstrously large, but good for a CA-series engine.
N15 Core size 320 X 648
Posted on: 2013/1/8 0:13
From Brisbane, QLD
Posted on: 2013/1/8 0:15
Edited by crab45 on 2013/9/12 15:05:50
76 B120 - Parted out in 2015 and gone to a better place
91 GB122 - Sold in 2017 to a kid doin' a resto on it
71 B110 - Almost RIP, long road ahead
From Sydney, NSW
Thanks for all the reply guys! would the gemini or n13/14 radiators allow for a condenser off to the left or right for air con?
Cheers,
Tom
Posted on: 2013/1/8 0:32
The pulsar ones fill the whole nose cone between the chassis rails. Sits between bumper bolts. You would sit AC condenser in front but the hoses would need to go around the sides of what ever rad you use. Also the condenser needs a fan most likely to push air through it.
Additionally Condenser blocks partial airflow through rad making it not as efficient.
So if adding AC you will need bigger rad.
Id get a Gemini one if stock to mild a series
Posted on: 2013/1/8 1:55
From Adelaide
I used an aluminium civc one "EK 95-00" but this was before you could get the 1200 aluminium 3 cores off ebay. One of those should be fine for your cooling needs. Unless you're doing burnouts for long periods of time in hot weather.
Posted on: 2013/1/8 6:58
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
If any one in Melb wants an s13 rad I have one that I had rodded and new top tank on last year. Otherwise it's out to hard rubbish. No room to store it.
Posted on: 2013/1/9 1:49
unfamilia,
id be interested in it if its the sr manual one.
Posted on: 2013/1/9 2:03
CA auto one I cut the auto Trans barbs off
Posted on: 2013/1/9 2:13
(1) 2 3 »
