what dato up to the job
From BlueMountains NSW
I got a 1965/70 13ft caravan and thinking bout hooking it up to a dato/ nissan for club runs. Which Dato from 70's would be up for job. Any Ideas
Posted on: 2013/1/8 5:12
I DON'T LIVE IN THE PAST....I JUST TAKE DAY TRIPS
Re: what dato up to the job
Any of the l4 might but any thing with an L6 should do it easy enough. 260c or 240k sedan.could be cool. Even a wagon of sorts for the full family.look.
Posted on: 2013/1/8 5:58
From Brisbane, QLD
kenmeri
Posted on: 2013/1/8 6:14
71 B110
The very best would be the 620. It can tow a heavy rig.
Posted on: 2013/1/8 6:47
From Adelaide. SA
Back in the day, we used to tow an RX3 to the drags with a 1200 ute (a15 power!!) and I used to tow a rally 1200 with a sunny panel van (a12)... so any datto is up to the task!
Cheers.
Adam.
Posted on: 2013/1/8 21:04
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
Club Runs are often on mountain highways, are they not? Most Datsun will not be good towing a 13-ft trailer up and down hills.
To go up hills requires more power (or lower gear ratio) and requires a strong chassis mount.
To go down hills safely requires weight. Excellent brakes alone will not do it.
Posted on: 2013/1/8 21:25
From Wanneroo, Western Australia
Get a Homer!
Posted on: 2013/1/9 0:41
Yes get a homer
Posted on: 2013/1/9 0:56
From Adelaide
Having brakes on the caravan should help if the car's on the light side. Will make it more stable to.
Posted on: 2013/1/9 1:33
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Amazing that you knew I was referring to the Powell and not the Datsun!
Posted on: 2013/1/9 2:01
