Tyre Touching Front Shocks While Turning ?
From Sri Lanka
Hi Guys
I am just thinking on putting a little big tyre set for the b210 just like 165/70-13 or 165/80-12 but currently i am using 155/80-12 yet sometimes the tyre is touching the shock absorber while hard turning ,what should be the solution for this how can i sort out this issue ?
thanks
regards
sumith
Posted on: 2013/2/8 10:09
Re: Tyre Touching Front Shocks While Turning ?
Not too shy to talk
From Rockhampton Qld
Sounds like wheel bearings are shot, jack up front of car ,grab wheel top & bottom,push & pull. Should be almost no movement.
Posted on: 2013/2/8 11:30
From Brisbane, QLD
might be the tire wall flexing under hard cornering thats touching the struts
Posted on: 2013/2/8 11:45
71 B110
Not too shy to talk
Maybe, but I think any flex happening [at contact patch] would have corrected itself by the time it got to shock absorber body [180 degrees away], even on this rocket.
Posted on: 2013/2/8 12:09
Sounds like something not right there. Is this on 120y or the b310?
Posted on: 2013/2/8 12:55
Sounds like wheel bearing to me as well
Posted on: 2013/2/9 0:05
Car free
From Sri Lanka
Hi Guys
This is my 120Y , when i look down the wheel from inside it sees the tyre is almost very closer to the shock absorber body.i will upload a snap probably on monday, how it looks
thanks
regards
sumith
Posted on: 2013/2/9 5:45
Maybe wheel off set is the problem
Posted on: 2013/2/9 6:19
Car free
Yes, something is WRONG.
In a stock B210, there is no possible way this can occur. The stock 4x12" wheel positions the tire far, far away from the strut tube.
* Wheel: 4x12" +30
* Tire 155SR12
Posted on: 2013/2/9 20:28
From Sri Lanka
Hi Guys
Look at this and what should be done to avoid this am i using different Shcoks or what is wrong here ? i think i would not be able to use higher rim size like 14, yet it will touch the shocks
thanks
regards
sumith
jpg  1.jpg (69.17 KB)
10994_5199a51ef0508.jpg 480X640 px
jpg  2.jpg (78.38 KB)
10994_5199a52821f46.jpg 480X640 px
Posted on: 2013/5/20 5:23
