« 1 (2) 3 »
Re: Short Boss Kit - Suit Ute/Quick Release/Deep Dish - Datskool
Quite a regular
Hi Bryan,
that would depend on how you wanted to finish it off,but with a wheel mounted to the short boss and put on the car the steering column thread will sit around 5mm past (stick out from) the flat surface of the wheel
You could run no spacer or the spacer could be machined down to be a lot thinner easily also.
Posted on: 2013/2/6 22:59
From Canberra
Ok thats what I suspected.
This won't work for me as I have a quick release hub attached to the boss.
This sits flush against the boss kit and does not have a large enough hole to accomodate the nut.
If you have a solution I would be interested.
Cheers
Bryan
Posted on: 2013/2/6 23:33
From Sydney
You could still fit the quick release with the spacer installed, or at least a spacer just thick enough to provide the required clearance...
Posted on: 2013/2/7 1:34
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From NSW
im interested.. let me know when they are available, pm or txt me on 0417495995.
Posted on: 2013/2/7 1:51
Quite a regular
I could supply or point you in the right direction to purchase a quick release which will work, this would replace the spacer and sit behind your steering wheel (between boss and wheel) it's pretty neat at only 25mm thick
Posted on: 2013/2/7 2:02
From Canberra
Already have quick release so not keen to purchase another one.
As Benny said, I could always just do hub/spacer/quick release/wheel.
Not sure if these are mass produced or could get one with a little more thickness to accommodate the thickness of the nut? let me know. Happy to discuss through PM if preferred.
Posted on: 2013/2/7 2:55
From NSW
Datskool, do you still have one of the samples available??
Posted on: 2013/2/7 6:10
From Sydney
You could also mill your existing boss to a height that suits and retap the 6 mounting points for the quick release base.
Posted on: 2013/2/7 7:39
1970 KB10 Coupe
S13 caliper b...
From NSW
datskool, will the boss kits suit a sparco p260 steering wheel??
jpg  $(KGrHqF,!icE5gFR+vM9BO,ztKLjW!~~60_58.JPG (32.68 KB)
3190_511a12deb566b.jpg 640X567 px
Posted on: 2013/2/12 10:01
Quite a regular
Hi DON sorry i missed your question earlier, no samples available now
i'm not sure about that sparco, do you have any idea what the bolt pattern is?, perhaps the best is to try one on any normal boss kit to see if they line up?
Posted on: 2013/2/12 10:18
« 1 (2) 3 »
