Exhaust size?
From Snohomish, WA USA
I just realized something yesterday. Last year I had a new 2" exhaust installed. Glaspak muffler and no Cat. So basically a straight pipe. Stock KA24DE 240SX has 2" but with restrictive muffler and Cat.
With the supercharger, the 240SX websites say you need 3" pipe.
What are you Modified 1200 people using? (CA, SR, L etc.)
And what should I use?
Posted on: 2013/2/17 15:55
Edited by datsa73 on 2013/2/17 16:57:34
Edited by datsa73 on 2013/2/17 16:59:58
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Re: Exhaust size?
From Brisbane
Using 3 inch system with S type muffler, hot dog and cat (CA). Cat is a bit restrictive, reduces top end power. 2.5 inch tip. Without tip the engine is a bit noisy.
Posted on: 2013/2/18 1:19
Re: Exhaust size?
From Goulburn NSW
Do u have to run a cat legally?
Posted on: 2013/2/18 1:33
Re: Exhaust size?
From Brisbane
yes. big fine if you dont. inpounded car if the cops in bad mood
Posted on: 2013/2/18 3:00
Re: Exhaust size?
From Sydney, Australia
2.5-3.0 inch exhaust needed for 150-200kW.
Posted on: 2013/2/18 9:40
Re: Exhaust size?
I'm guessing its all new exhaust for me this year.
Now I have to decide between 2.5 and 3 inch. I'm not to concerned about the noise. I just want good flow.
Posted on: 2013/2/18 16:01
'73 2 Door Sedan
Re: Exhaust size?
From stinking hot cairns
Don't s/c still need good exhorts velocity unlike turbos? If that is the case bigger is not better and I would think a straight through 2.5 would be a good size.
Posted on: 2013/2/19 1:09
