« 1 (2) 3 4 5 ... 7 »
Re: Ange's 1200 sedan
Stop looking at his as lamby.... You should be looking under his hood. I don't see high beams
Posted on: 2013/3/24 6:37
From Adelaide
Credit where credit's due!
Posted on: 2013/3/24 6:58
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Melbourne,Australia
Looking good bay's changed a bit since I last saw it
Posted on: 2013/3/24 6:59
From MOOROODUC. Victoria
Wow, Mint flavoured !
Posted on: 2013/3/24 8:13
Yeah oath! That bay is looking much more different since i saw it!! Looking good mate, look forward to seeing it go at datnats!!
Posted on: 2013/3/24 8:33
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
From Melbourne AUS
small update, not a lot has happened with the car this year ive just sorted through the wiring
after i had electrical gremlins at datnats back in march
ive since had it on the dyno where it made 121kw at the rears and i had it out at winton
for a recent practice day and did 50+ laps trouble free
best lap was a 1m41.24 in the first session, then struggled for grip the rest of the day
as my tyres had run out of life. im still probably 2-3 seconds off where i could be but that
should come with some new tyres and a bit more time spent in the drivers seat...
im looking forward to getting it out more often and i'll make sure the next update has some pics to go with it
Posted on: 2013/9/6 14:25
1973 B110 A12
That's sweet Ange hope to see u at some track meets next year can't wait! Sedan looks nice, what ended up being your problem at datnats?
Posted on: 2013/9/6 15:07
Car free
From Snohomish, WA USA
Nice looking car and motor! Well done job!!
Posted on: 2013/9/6 20:47
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Ive got a couple of pics from the pits on Friday mate and a small vid of you in action if I can work out how to put it up
Posted on: 2013/9/7 2:07
From Melbourne AUS
if you could stu thatd be good otherwise email them across and ill find a way..
nick basically i had intermittent cylinder sync errors but only at high load & rpm
which made it difficult to diagnose. The cause is still a bit of an unknown but i have
made quite a few changes in areas that may have been the culprit.
good news is that it has endured the dyno runs and a test day at the track without a
single sync error so looks like its all good in that department
will now try and squeeze a bit more performance out of the driver!
Posted on: 2013/9/7 14:12
1973 B110 A12
