Electric Choke Fully Open Stuck ?
From Sri Lanka
Hi Guys
What would be the impact on the electric Choke Is fully open always (means choke butterfly is fully open and stuck and doesn't close when the engine is cold
i have that situation on my b310 can i sort it out or need to buy another choke or carburetor ?
thanks
regards
sumith
Posted on: 2013/1/16 4:34
Re: Electric Choke Fully Open Stuck ?
Symptoms include: difficult to start when cold, will not idle when cold, backfiring, hesitation.
When warm, it will work as normal.
No need to buy anything, instead inspect the choke and the linkage. It is likely put on incorrectly.
Posted on: 2013/1/16 5:10
From Sri Lanka
Hi Guys
just a small question,Is it activating on Voltage provided or according to the engine temperature change ?
thanks
regards
sumith
Posted on: 2013/1/19 4:41
The choke is activated by IGN voltage.
It is only indirectly affected by engine heat.
Posted on: 2013/1/19 6:07
From Sri Lanka
Hi Guys
I checked my electric choke removed it and fixed it back , It is nicely opening while engine is warming up , But doesn't close when engine becomes cold when you touch a linkage handle by hand with a tick sound it closes it it stuck somewhere or is there a spring or something for it to close or is it automatically has to come to close position ? what would be the cause ?
thanks
regards
sumith
jpg  carb.jpg (71.59 KB)
10994_5159085b8645e.jpg 640X480 px
Posted on: 2013/4/1 5:11
The method to adjust the choke, is to set it so that it just barely closes 100% when cold. Do not adjust it to fully open (the electric connection will do that).
The choke will not close fully when cold until the throttle is slightly opened. This will happen when you touch your foot to the accelerator pedal.
Posted on: 2013/4/1 5:52
From Sri Lanka
Hi DD
Ok so it means when i press the accelerator pedal a bit if the engine is cold it will automatically close the choke and eventually open it while engine is warming up again ? is it ?
if so there there is nothing wrong with my electric choke
there was a piece of iron wire that has been tighten to keep the choke plate open (by the previous owner) , So i thought the electric choke doesn't work , earlier it did not work but after re fixing it works great,
i will check the accelerator pedal and see it back and let you know
thanks
regards
sumith
Posted on: 2013/4/1 6:38
Yes, that is correct.
Posted on: 2013/4/1 6:47
From Sri Lanka
Hi Guys
I went and checked my Choke It was fully open since last drive, then pushed the accelerator pedal a bit and tried it did not close and then started it ,car started but choke butterfly did not move ,i went and pulled the linkage then with a tic noise it closed ,am i missing something or anything wrong with re fixing process ? what sort of a link between throttle and choke butterfly when the engine is cold ? help me please
thanks
regards
sumith
Posted on: 2013/4/2 4:17
There is no link between the accelerator cable and choke. There is a link between the throttle lever and the choke at the carburetor. It only needs cleaning to remove grease and dust. Spray with special carburetor cleaner or with ether.
Posted on: 2013/4/2 4:24
