Browsing this Thread:
1 Anonymous Users
Re: Sunny Truck Project 4AGE |
From SYDNEY,NSW
going great so far!!!! top choice of engine ...
Posted on: 2012/9/7 11:03
vouch points for PIGDOG J-Dat dats-me TRAV 40RST minitruckin 120fly DEMO 1200dat aidaniel matty discobob mick1200 cemax DATSKOOL - all have helped me out with parts...Thankyou
From A-TOWN
Thanks mate, how is yours coming along?
Posted on: 2012/10/24 13:22
From A-TOWN
gettin closer
Posted on: 2013/3/29 10:02
From A-TOWN
finished all the wiring, turned over on the first #OOPS#, everything is sparking, charging and running right. Have done the fuel system but not really happy with it, gonna run a regulator, gauge and plumb a return line. Engine sounds healthy turning over, with a fresh set of plugs and timing it should kick over no worries. \ Also put in a new clutch fork and bled the maddat kit. Have got a TRD 2 way to put in when i can track down a ute diff housing to modify, may need to modify the tail shaft to fit the diff flange but doesn't look to big of a job. Once thats done its just a matter of bolting the radiator in, thermo fan wiring is done, sus out what i wanna do with rear suspension, new exhaust and she will be pretty much done.
Posted on: 2013/4/8 5:36
From MOOROODUC. Victoria
I remember saying "pretty much done" ... 6 months later well, it's pretty much done
keep up the good work
Posted on: 2013/4/8 6:12
Red 1200 Coupe (Build: DEMAC's 1200 Coupe) Blue 1200 Ute, CA18DE Auto (Build: DEMAC's 1200 Ute) Green 1200 Sedan (Build: Kermit the beat up sedan) Green Sedan #2 (Current build: DEMAC's 1200 Sedan)
From A-TOWN
haha yeah im hearing ya, but once its running thats it, im defiantly not painting it, interior is staying the same, wheels are staying etc. Mite add some cams, gears, head work, hydro hand brake etc. along the track but thats all pissy little weekend jobs. Pretty stoked how its turned out that, wasnt easy trying to build it over 3 years on an apprentice wage in a carport.
Posted on: 2013/4/8 6:47
Not too shy to talk
hi what differential did you use or is it the standard differential?
Posted on: 2013/4/10 20:41
From A-TOWN
I've got a Toyota TRD two way centre out of AE86 with 24mm spline to put in the ute housing, word on the street is they fit, just need to drill n tap a few holes on the housing. It's 10mm shorter than the ute centre so should be taken up in the yolk but I'm gonna fab up a little alloy spacer so everything sits nice, tight and flush.
So yeah, Toyota engine, box and diff. None of this #OOPS#ty plastic datsun #OOPS#.
Posted on: 2013/4/11 2:59
From south coast nsw
Haven't been on here in ages,didnt read the whole thred properly but i do have to say this is sic. This will seriously haul with cams springs and 45s. u can't engineer this engine at all with carbs but thought?
Posted on: 2013/4/15 12:47
From A-TOWN
Thanks man, im sure it will be able to be engineered. In Adelaide its legal till you get caught :)
got my eyes on a set of HKS cams, gears n springs. Just hanging to thrash the balls off it.
Posted on: 2013/4/15 14:05
