Re: Approx Price to Sandblast Ute tray and epoxy prime
From Western Australia
thanks DB
so complete sandblast and 2 pac prime is an overkill/unnecessary?
found apparently can order through Auto One
torn as to if I should DIY prep or add $400 for blast and 2 pac prime.
if I blast, prime and get the U pol kit its $700 anyway, almost cost of complete professional job! :-S
Posted on: 2013/4/29 10:21
1974 1200 Ute - Build
From Goulburn NSW
Hey guys whats the difference between sodablasting and beadblasting?
Posted on: 2013/4/29 10:26
From Adelaide
The difference between sand and soda blasting is the abrasive/ media. i.e. sand and sodium bicarbonate.
Posted on: 2013/4/29 10:38
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Goulburn NSW
Yeah I know what sandblasting is and sodablasting is but what do they use for beadblasting?
Posted on: 2013/4/29 10:53
The whole terminology of media blasting is twisted.
You bead blast glass bead.
Sand blast sand, which is a very large range of different material.
Shot blast, metal shot, shot peen.
Garnet is fantastic for automotive application, once used material is my preference.
Glass powder gives a magnificent result on softer metals.
Posted on: 2013/4/29 10:59
There are probably thousands of different blast media mcdat, you might want to take your question to the old google. Search media blast abrasives or something along those lines.
Posted on: 2013/4/29 11:02
From Narellan,Sydney
As clyons8 said there's lots if different materials they use in bead blasting.im pretty sure they used plastic beads with mine but I can't remember 100%
Posted on: 2013/4/29 11:17
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
If you are going to use a spray on liner, then sodablasting or sandblasting is a waste of money. If you can do it yourself maybe go ahead and do it but I didnt blast mine or anything. Just used scour's and water to clean it and used prepsol to get any foreign grease/residue off.
Just used etch primer and the raptor liner. Comes in 4 x 1 litre bottles and you can get a shutz gun on eBay for $20 and spray it yourself. Just makes a mess
Posted on: 2013/4/29 13:56
Cheers DB thats what im thinkin
Last q are all etch primers compatible?
Ive got hichem 1k super etch epoxy for large areas and was goin to use generic etch in spray can for small areas are they ok
Posted on: 2013/4/29 14:14
« 1 (2)
