« 1 ... 33 34 35 (36) 37 38 39 ... 49 »
Re: Datsun 1200 Sedan Build
Zip ties, the universal attachment item.
Posted on: 2013/5/14 14:38
From Trinidad and tobago
UPDATE
Yes zip ties work very well!
Put on the cylinder head and both manifolds too.
Pics
Check out how close the exhaust is to the engine brackets
More soon!
Posted on: 2013/5/17 13:42
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
From Snohomish, WA USA
Very Clean!!
Posted on: 2013/5/17 17:47
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Thanks man!
Oil Catch Can installed.Getting closer an closer
Posted on: 2013/5/20 3:20
Street Sleeper!
I like your work Darren. She is looking good this car.
Are your pipes running to your oil catch can K&N as well lol...
Keep up the good work. I look forward to being at the stage your at.
Posted on: 2013/5/20 7:25
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
Nice and tidy! Be sure to keep an eye on that plastic piping on the exhaust side.
Blood orange coloured a15.
Posted on: 2013/5/20 8:46
Thromoswitch On the rad.
High EnergyCoil.
Alternator i an Belt tightened
More to come.Basically hooking up wires now.
Posted on: 2013/5/22 3:35
Street Sleeper!
From MOOROODUC. Victoria
The thing you can count on with this build is that you won't get your hands too dirty ... it's all clean and painted
Posted on: 2013/5/22 8:44
From WA perth
looks good, but your thomo switch is in the wrong place. it should be in the top of the radiator the hottest part ,the bottom is the coldest
Posted on: 2013/5/22 14:05
Also that thermostat housing has seen better days.
Looks good.
Get some better hose to the catch can too. I use heater hose usually. Hot water hot oil, it will travel if it needs to.
Posted on: 2013/5/22 16:29
