« 1 (2)
Re: Got pulled over for "too loud" (Video/Audio now up)
burnt squirrel or Opossum skeleton tickling the muffler?
Posted on: 2013/5/20 14:39
From Cape Town ZA
I'm sure it's not, but it sounds very similar to valve bounce.
Posted on: 2013/5/20 15:22
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
Hmmm ... it does not seem to lose power when it makes the noise, and will rev higher at which point the noise ceases.
Posted on: 2013/5/20 17:09
From Adelaide
I'd suspect something in the carbies making the noise but without fiddling around with it and a piece of diagnostic garden hose it's hard to guess. Having a dyno so you could run it up and then get around it with the hose to pin point the source would be very useful. I'm sure someone on this forum has come across it before...
My thinking is that there might be some kind of restriction or resonance going on there or something's not quite tight. COuld even be a piece of gasket partially obscuring a passage in the carb making the noise at a particular speed. You'll figure it out I'm sure.
Posted on: 2013/5/21 6:24
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
« 1 (2)
