Gear lever bushes
From Adelaide, SA
Morning, just after a bit of advice as I couldn’t seem to find exactly what I was after by searching. The gear lever in my 79 sunny is a bit sloppy, previously I have used some circles I cut out of a nylon chopping board for new bushes which worked pretty well to fix this up (mind you the wife wasn’t too pleased). Is there a proper replacement part?
Found these on ebay but the application says 'some Datsun'.
All standard parts, I think that means it has the 56 series? 4 speed anyway.
Posted on: 2013/5/21 18:01
Edited by sunny_man on 2013/5/21 21:11:44
Re: Gear lever bushes
From Brisbane, QLD
They look like they'll fit.
Might want to double check with the seller to see if they'll definitely fit your Sunny.
Posted on: 2013/5/21 22:35
71 B110
From Brisbane, Australia
pretty sure they're cheaper than that from Nissan. You normally only need the two for the shifter pin - the bottom one doesn't seem to wear. I bought some recently and they were in stock at the local dealer.
Posted on: 2013/5/21 23:05
From Adelaide, SA
Ah sweet, thanks guys, will check that out.
Posted on: 2013/5/21 23:52
