A15 80hp /67hp
From Mordialloc Victoria 3195
Hey there. Can someone enlighten me as to the internal and external physical differences between the 80 and 67 hp A15's. Couldn't find it in tech wiki
Cheers D.
Posted on: 2013/5/25 2:13
Re: A15 80hp /67hp
some have comp differences due to h75 open chamber head the other h89 close chamber, different pollution gear, exhaust & inlet manifolds and would think the 67hp one could also be another possible head the swirl round port.
Posted on: 2013/5/25 2:34
Re: A15 80hp /67hp
From Townsville, Qld
The,67 would most likely be the forklift variant
Posted on: 2013/5/25 2:48
Re: A15 80hp /67hp
From Brisbane, QLD
Does it really matter which one you get it you plan to do a full rebuild?
I remember someone saying if you get the lower HP varient, to bin it and find a higher HP one.
If you're planning a full rebuild, i.e. bore it out, new cam, new valves, porting etc etc, it would kinda cancel out the initial comp differences?
Posted on: 2013/5/25 2:54
71 B110
Re: A15 80hp /67hp
67 HP was small-port cylinder head. Came in around 1982
Along with the changes D mentioned, the cam is smaller duration. Not a forklift engine. Came in last of the B310s and in the Vanette.
A 'full rebuild' will not change the HP design. Changing the cylinder head and camshaft is what is needed. And then rev it up while you drive it!
Posted on: 2013/5/25 6:28
Re: A15 80hp /67hp
or have the ports opened up and cam change as DD mentioned
tuned with 32/36 weber, headers and good ignition
Posted on: 2013/5/25 9:59
Edited by D on 2013/5/25 11:34:25
Re: A15 80hp /67hp
From Trinidad and tobago
WHat head did the 67hp a15 come with?
Posted on: 2013/5/25 15:52
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: A15 80hp /67hp
""67 HP was small-port cylinder head. Came in around 1982""
Posted on: 2013/5/26 3:06
Re: A15 80hp /67hp
So from ouside they look the same ? Is there markings on the head which would tell you or do you need to have the manifold off to see if it has the small port head ?
Cheers D
Posted on: 2013/5/26 12:40
keep it simple
Re: A15 80hp /67hp
Valve cover off -- reading the casting numbers
or
Manifold off -- measure the size of the ports (small oval, medium oval, large oval, or round port)
Posted on: 2013/5/26 19:38
