help tuning my twin webers
From Canberra
Hey guys I really need a hand to tune my twin 45 webers..
The ute itself runs great on idle and when I push down the linkage slowly but if I am to push down the linkage quickly the webers them self die as though not enough fuel or air..
I have the first and second inlets backfiring and the exhaust make a poping backfire...
I am sure the timing right and the gap is correct I have tried advancing and decreasing the distributor and play around with the mixture screws but they are already screwed in all the way..
Any help would be greatly appreciated. . I really have no idea to get these synchronized correctly. .
Posted on: 2013/6/22 7:56
Re: help tuning my twin webers
Sounds like it mainly needs more accelerator pump. This is common problem when using carbs too big for the engine.
Posted on: 2013/6/22 8:19
From Canberra
Mhmm.. Well my A15 is mildly worked so I'm assuming "D" I will need a larger fuel pump.? Or what is the best way to solve this..
Will changing the jets make any difference
Posted on: 2013/6/22 11:10
Edited by loosekid on 2013/6/22 11:26:35
From Canberra
From what my old man thinks it might be
34mm chokes
45 aux venturi
125 main jet
180 air correcter
F16 emulsion tube
45 f12 idle
50 pump jet
So if I go ahead and change the pump jet would it make a difference or make the chokes 32mm
Posted on: 2013/6/22 11:14
From Sydney, Australia
The fronts are backfiring through carby from not enough idle mixture.
The off idle stumble is because of the big venturis. If this is an a-series.. 30 venturis and 40f9 should be better.
if the carbies are second hand they might need a new gasket kit applied.
Im assuming you know how to set float level and how to sychronise the carbies too?
Posted on: 2013/6/22 14:31
An upgraded Fuel pump is not needed for a mildy worked A15. The stock Datsun mechanical fuel pump has adequate volume and perfect pressure for Webers.
I would try a larger accelerator pump jet if the carburetors "die" when the accelerator pedal is quickly opened. Also check the float level.
I use 32mm venturis on my A12 and get occasional popping (backfiring) on part-throttle, but the same thing occurred on the 1522 engine. I experience zero off-idle stumble.
Posted on: 2013/6/22 20:14
From Canberra
Cheers boys and yeah they are brand new carbs ill try what you suggested and see how I go
Posted on: 2013/6/23 5:27
Edited by loosekid on 2013/6/23 8:29:23
From mandurah
Sounds like throttle pump jet is too small , try the next size up and maybe adjust how much it pumps out
My 40mm solexs did this , and I adjusted the throttle pump rod to add more fuel , which worked cos I had the right size jet but wasnt pumping enough fuel through it
Good luck man they are a thing of art when tuned properly
Posted on: 2013/6/23 5:34
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
