« 1 (2) 3 4 »
Re: engine problem
Have you checked that the fuel pump is adequately providing fuel to the carbie?
Posted on: 2013/6/24 7:14
Re: engine problem
From stinking hot cairns
did you just clean the bowl? or the jets, emulation tubes and obviously the rest of the idle circuit? also if it happened after you filed up you would think there is probably more #OOPS# in the tank.
Posted on: 2013/6/24 7:38
Re: engine problem
Quite a regular
hi all, I took off the carb took out the secondary main jet and primary jet and blew compressed air through out no sign of water in fuel I took hose off held a container in front of hose plenty of petrol came through after all that, its idles better and when I rev it up it back fires through carb
Posted on: 2013/6/24 9:15
Re: engine problem
Quite a regular
I just had a prob like that and it turned out to be a fouled plug. Idled fine but misfired on acceleration. Cleaned and reset plugs ad all fine
ZM
Posted on: 2013/6/24 11:53
Re: engine problem
Quite a regular
checked all plug gaps and cleaned and checked points and timing that stop that stopped the back firing, now when it idles its up and down and blows blue smoke, I try to adjust carb to lean still change
Posted on: 2013/6/25 4:46
Re: engine problem
Congrats on solving the backfiring problem.
Blowing blue smoke ... ensure the oil level is not overfull. Otherwise most likely the engine needs an overhaul.
Posted on: 2013/6/25 4:55
Re: engine problem
Quite a regular
thanks, the engine been done the end of 2012 its done very little k,s
Posted on: 2013/6/25 5:54
Re: engine problem
From Sydney
Rings may not have bedded in correctly since the rebuild leading to excessive oil on the bores resulting in burning and blue smoke.
Posted on: 2013/6/25 6:49
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: engine problem
Quite a regular
when idling very little but when I rev it up it blows a lot more blue smoke would it possible be only valve stems seals??
Posted on: 2013/6/26 7:29
Re: engine problem
Valve stem seals usualy at idle or on take off. Rings usually at revs as far as I know
Posted on: 2013/6/26 9:11
« 1 (2) 3 4 »
