Browsing this Thread:
1 Anonymous Users
Reverse light issue |
From Vanderbijlpark, South Africa
I recently started fixing up a few things on the ute, I installed a new reverse switch as mine was not working since I got it, when I press the switch the reverse lights both work but when I install it in the 60a 5 spd gearbox it does not work, there are 2 swtiches available, one lights up when depressed on the switch and the other one when not depressed, tried either with no luck when screwed in. is there suppose to be a spacer of some sort or might something be broken inside ther gearbox. all help greatly appreciated
Posted on: 2013/7/9 7:19
93' Nissan 1400 a15 60a (daily) 82' Datsun 1400 ute (sold) 73' Datsun 1200gx Coupe (sold)
Re: Reverse light issue |
From Stone Age somewhere in U.S.A.
More than likely you are missing a steel ball about 8mm in diameter. This would go into the hole before the switch is installed. It would be a good idea to get an exploded view of the trans case, or see your local dealer.
Posted on: 2013/7/9 15:13
Registered Users Contentmaster Usermaster
early 56-series and late 56/60-series transmissions use different Reverse Lamp Switches
Posted on: 2013/7/16 7:28
