New H165 LSD
From Victoria
Hi guys I thought you might like to see a pic of my new H165 LSD.
jpg  IMG_0511.jpg (99.18 KB)
2370_5232ae0aa34d2.jpg 640X480 px
Posted on: 2013/9/13 7:18
Re: New H165 LSD
From Sydney
What ratio did you fit it to
Posted on: 2013/9/13 7:25
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: New H165 LSD
From Victoria
Posted on: 2013/9/13 7:36
Re: New H165 LSD
From Melbourne, Australia
Topgear center?
or Toyota
I've been wondering if my topgear center can be used in a 4.875 because i think they have a different crown wheel offset???
looks like you may have used a spacer?
Posted on: 2013/9/13 9:57
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: New H165 LSD
From Albury
Topgear Lsd works with 4.875 gearing no problems
Posted on: 2013/9/13 10:07
Re: New H165 LSD
sweet! thought i might have to go 4.1 in the rally car
Posted on: 2013/9/13 12:25
1200 Coupe Rallycar
Re: New H165 LSD
From Victoria
Look again there are no spacers in there. A 4.875 has a different offset to a 4.1 they are not the same.
Posted on: 2013/9/13 14:41
Re: New H165 LSD
Nismo sold two different H165 LSD units.
38420-N5020 for Type I carriers
* H165 old type: 3.889 to 4.625 旧型
* H165B low-tooth: 3.700 to 4.875 並歯型
38420-RS110 for Type II carriers
* H165B high-tooth: 3.154 to 4.875 高歯型
So either H165 unit can use 4.111 or 4.875 gearsets.
The H190 LSDs came in two different versions which require a spacer for some ratios.
Posted on: 2013/9/13 23:38
Re: New H165 LSD
hey dd,
abit off topic,
ive got a nismo 2 way 4.875 h165 lsd diff unit that was kept as a spare during TS.Not yet installed.
seller did write high tooth.
But is there a way to confirm if its low tooth or high tooth,type 1 or type 2 carrier?
or any markings to differentiate between the two types?
sorry to go off topic
cheers
Posted on: 2013/9/14 0:55
Re: New H165 LSD
Is there any way to determine if the Differential Assembly is Type I or Type II (high tooth)? Good question. Perhaps there are casting marks on the unit. Or if the CWP/Ring&Pinion are still attached, they might have markings.
Which gearsets do the Topgear units accept? Type I gearsets or Type II gearsets?
Posted on: 2013/9/14 2:22
