Mikuni Bike Carbs
Quite a regular
Has anyone on here used any of the Mikuni bike carbs on a Dato 1200?
The carbs I am looking at are BS34's. These have the rubber diaphragm and round alloy top cover .These carbs are shown in a gallery pic on this site elsewhere and incorrectly labelled flat slide . They are different beasties.
http://datsun1200.com/modules/newbb/v ... mode=0&start=0&menumode=2
Of particular interest is the fuel delivery set up as they are normally gravity fed and don't withstand too much line pressure otherwise they will flood.
Any info or feed back appreciated.
Cheers
Posted on: 2013/9/24 0:51
Re: Mikuni Bike Carbs
Clyons8 has. Im planning on using some fz1000 race mikunis on my l18. Just waiting on manifold.
Use a fuel pressure reg or even a motorbike fuel pump for feeding the fuel.
Posted on: 2013/9/24 1:06
Mikuni 34mm round slide carburetors
SUs also have a round slide (piston) along with a traditional butterfly throttle plate.
Posted on: 2013/9/24 2:43
From Las Vegas USA
I've been running motorcycle carbs for a few years now. All you need is a fuel pressure regulator to limit it to 1.5 psi. I run a little bit less just on 1 psi. The float needles will seat at upward of 3 psi but it varies from carb to carb, stick to 1.5 and it will be fine.
As for the description flat slides are generally referring to mechanical operation to lift the slide versus a CV carb which uses a diaprhagm to lift the slide both types could have a "flat slide".
The CV type are a bit more,user friendly, a decade ago i ran a Yamaha 1000 powered single seat sports racer and it used CV style downdraft carbs which worked quite well. On my 1200 coupe I run the Keihin FCR flat slide carbs and they also are fantastic, as an motorcycle racer I am biased but I think bike carbs are better made and offer more performance
To,
Posted on: 2013/9/24 5:25
Rallytwit,
How do the Keihin FCR perform on the road compared to the CV type carbs, including fuel consumption?
I have Keihin CVK41 and FCR36, dunno which to use.
Posted on: 2013/9/24 5:40
Keihin FCR uses a flat slide as the throttle valve, while the Keihen CVK is slide venturi with butterfly-throttle.
41 mm will likely be overcarbed for an A-series engine. 36mm carbs will make plenty of power for 1400-1500cc engines.
Posted on: 2013/9/24 7:33
From Townsville, Qld
Awww, I'm not a bum, it just takes me a while to get stuff done.
Posted on: 2013/9/24 8:15
I was going to use the front set as it has the richest needles and smoothest action but I'll just transfer them over to one of the other carbs and build the manifold for that, there's 3 of those with the same spacing so they're probably Kawasaki or Yamaha ones, the black one in the front is off a Suzuki
Posted on: 2013/9/24 8:20
Quite a regular
Thanks for the responses everyone. That is useful info.
I have a set of these carbs being the BS34 models which I believe were fitted to a Yamaha XS1100 from the late 70's perhaps early 80's. What I have come to learn about these carbs is that from the factory on some models they set the two centre carbs a bit richer by fitting slightly fatter jets, say 115 on the outers and 120 on the inners. No doubt because they get less air to cool them and so run them a bit richer to try to keep the temperatures under control.This no doubt varied from manufacturer to manufacturer so any set you consider these issues should be kept in mind.
Thats all well and good on an air cooled engine but not a factor on anything that is watercooled. The needle heights are adjustable and have 5 different settings and so should be set the same on the bench before fitting up to the car.
Posted on: 2013/9/25 0:44
From Los Angeles,CA
I am running two Mikuni HSR42 carbs. So far they are excellent! The Throttle response is awesome and no flat spots. Super easy to tune. Large float bowls and an accelerator pump. Fit on standard Mikuni, Weber or S.U. manifolds.......
png  Bay26.png (199.85 KB)
8618_5242382d80ed9.png 672X504 px
png  Bay25.png (194.67 KB)
8618_5242384787907.png 610X458 px
png  Bay24.png (199.29 KB)
8618_524238652594e.png 664X498 px
png  Bay28.png (198.16 KB)
8618_52423901452ec.png 643X482 px
png  Carb1.png (198.46 KB)
8618_5242395b3f99e.png 499X666 px
Posted on: 2013/9/25 2:18
