Dash Removal
From Port Douglas. QLD
Anyone else had to deal with threaded screws on the top of the dash? Ive got two :(
Looks like a previous owner has had a crack at them with no luck.
i tried with little bent screw drivers, wd40, rubber bands, flat heads and a couple of other combinations with no luck.
Also the screws holding the heater controls are tight as fark.
Posted on: 2013/10/2 12:24
1200 ute
ca18det
Re: Dash Removal
If its only 1 left just chisel it off or dremel it. They are crap screws. The heater ones on one I had were glued in... I had to drill them out.
Posted on: 2013/10/2 12:38
Re: Dash Removal
Its definitely easier with the windscreen out but dont resort to that. Try a 90 degree bent shallow screwdriver
Posted on: 2013/10/2 16:38
Re: Dash Removal
I use a screwdriver bit and a combo wrench to turn it.
Posted on: 2013/10/2 19:23
Re: Dash Removal
From MOOROODUC. Victoria
get one of these .... they are invaluable
jpg  rightangle.jpg (7.87 KB)
8710_524d1112d0517.jpg 300X300 px
Posted on: 2013/10/3 7:39
Re: Dash Removal
From NSW, Australia
I too recommend ddgonzal trick. worked for me.
Posted on: 2013/10/4 6:01
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
