DOUBLE VALVE SPRINGS PARTS NUMBER
From Albury
Hey Guys.
I am chasing a set of double valve springs for a H89 head with a fair cam in it. Any ideas on poundages annd or parts numbers ??
Thanks
Bob
Posted on: 2013/11/6 5:46
Re: DOUBLE VALVE SPRINGS PARTS NUMBER
Factory dual springs are good for about 7000 rpm. Specs are at Valve Springs
* 13203-H2300 SPRING-valve, outer
* 13203-H2301 SPRING-valve, inner
* 13205-H2300 SEAT-valve spring
Tomei or Isky and most after market duals are good for about 9000 rpm.
Posted on: 2013/11/6 7:15
From sydney australia
I just picked up a set of twin valve springs from SWR Motorsport for $104. The invoice doesn't have a part number, but I'm sure if you call them on 02-4577-2400, they can supply & mail them to you. I'm using them in a H89 head with an Arthur Johnson AJS35S cam in an A15. Should do the job.
Posted on: 2013/11/6 8:25
From vic
http://www.performancesprings.com.au/valvesprings.html
I got my dual springs from these seems to be good quality cost was $125 with free express postage
my engine with the cam and head work i have right know revs to 7200rpm easily with these springs.
Posted on: 2013/11/6 9:24
