« 1 2 3 (4) 5 6 7 ... 9 »
Re: Ca18det 1200 ute.
From NSW
hi mate sweet looking build.. Just curious, i am looking at running a similar dash to yours.. wondering which combo of dash and computer you went with and did you have any trouble marrying up sensors ect..??
Posted on: 2013/11/5 10:01
From Mudgee NSW Australia
I'm running the Haltech PS1000 ECU and Racepac dash. Had Justin at Prowire wire it all up for me. Most of it just plugged in and your away. Uses some factory sensors and some Haltech sensors so far no issues. ECU controls fuel pumps, oil cooler fan, thermos, boost control, Factory CAS, LS2 coils, launch control ect ect.
Posted on: 2013/11/5 11:03
If In doubt run more BOOST
From NSW
thanks for the info.. much appreciated...
Posted on: 2013/11/6 11:52
Well after much time money and frustration the Datto ute has finally done me proud.
Making really good power with more to be had once run in properly. Car feels nice and strong everything seems to be hanging together.
Ready to start doing some track work.EC off street drags next week and Wakefield park the 19th of next month.
She made 280rwkw @20psi full boost@4300rpm and 341kw @30psi full boost@4800. Here is a short video of her on the dyno
https://www.youtube.com/watch?v=gYtTGb_Qo9w
Posted on: 2014/5/29 12:57
From Brisbane
Nice work! Contact spool imports might put a story on the build page. Another 8psi should get 380kw hehe. Should do 10s now tho :) whats it feel like hitting boost. Makes me want to finish my car now
Posted on: 2014/5/30 0:51
Thanks just run 11.5@125mph with 20psi. A very soft take off. Happy with how its running and sounds so sweet mad induction noise for a turbo motor. Here is an Incar video of my run https://www.youtube.com/watch?v=jJiiquvv-V8
Posted on: 2014/6/11 9:05
From Canberra
Andrew,
Do you have any info on how you attached the RB25 gearbox to the CA18, plus any tunnel mods.
Cheers
Bryan
Posted on: 2014/6/18 2:18
From Goulburn NSW
I'd like to know to,mainly tunnel mods.
Posted on: 2014/6/28 10:16
Edited by mcdat on 2014/6/28 10:44:23
Im using a Maddat transmission tunnel the gearbox is bloody huge had to massage around the bottom in a few spots.
The gearbox itself was a fair bit of work had a machinist friend do a lot of the work for me. Cut 50mm off the front of the RB gearbox and machined it flat. Cut 50mm off the front of a CA20 gearbox from a bluebird and machined it flat cut a 3mm aluminium ring and welded it all together making sure was in the correct position. Used a stock CA box to jig the right location. I have some pictures of the process on FB files are to big to upload here.
https://www.facebook.com/photo.php?fbi ... .817179524&type=3&theater
Posted on: 2014/6/28 12:18
From Goulburn NSW
Hey mate did u have to do anything to the maddat tunnel?
Posted on: 2014/6/29 2:45
