Mounting ca18
From Port Douglas. QLD
Just got my crossmember from Kev Rowley. Has anyone used any other engine mounts other than the stock s13 ones with one of these crossmembers?
Posted on: 2013/11/8 12:15
1200 ute
ca18det
Re: Mounting ca18
Quite a regular
not sure about kev rowley crossmember
but maddat ones use similar to this
http://www.ebay.com.au/itm/Land-Rover ... ories&hash=item3a8623e6f4
Posted on: 2013/11/8 23:53
gathering bog dust in the "DATCAVE"-
1200 coupe a14 quad carbd dished wats daily project
1200 ute ca18det,minitubs,irs,flared,ssr mrk3 dished jdm custom project
1600 sedan l18 supercharged mrk 2s, fender mirrord daily
mazda b1800 pickup v6 bike h...
Re: Mounting ca18
From North Brisbane
Also just picked my crossmember up from Kev. Was also curious about this. Kevin designed his crossmember to the standard mounts because that is what came in the front cut. If you find another mount the same height as factory, they will still work. I will be using the factory style ones (not genuine) as they are fully silicon and will provide a good cushion and Kevin recommended to. But of course, each to there own.
Posted on: 2013/11/9 0:31
Re: Mounting ca18
i used cortina ones, i think they're round and the same height. do a search on here and you should find the thread
Posted on: 2013/11/9 3:32
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
Re: Mounting ca18
I brought kelpro cortina mounts as suggested on here. still seems to be way off fitting.
Posted on: 2013/11/9 5:06
1200 ute
ca18det
Re: Mounting ca18
going to order some ca18 ones
Posted on: 2013/11/9 5:07
1200 ute
ca18det
Re: Mounting ca18
From Brissy
I think the cortina ones are shorter than stock ca mounts but also a bit firmer. You may just need to file the crossmember slots a bit further down. they are better than stock mounts providing that there is enough clearance between the sump and the crossmember. A lower center of gravity is always good and lowering will give a tiny bit more clearance for the gearbox.
Posted on: 2013/11/9 6:33
Re: Mounting ca18
From North Brisbane
And I know the CA ones are off set. So I think in the opposite position you are able to get an extra 5mm clearance off the firewall.
Posted on: 2013/11/9 20:57
Re: Mounting ca18
i had no dramas hey, wasn't way off or anything still had good clearance off the crossmember
Posted on: 2013/11/9 22:34
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
Re: Mounting ca18
From MOOROODUC. Victoria
Bought cortina ones from Bursons .. they work well on my home made crossmember
Posted on: 2013/11/10 5:42
