« 1 2 (3) 4 »
Re: Classic Japan Meblourne
From Bendigo, Victoria
We all know you are king of the wristies Mik.
Hope you've got some better lube this year, everybody complained about the Magnatec you used last year.
Posted on: 2013/11/18 7:23
I really should have bought fresh stuff not used stuff from my sump.
Posted on: 2013/11/18 8:26
From Adelaide
See how we go, I've finally got my Quad Throttle bodies bolted up and plumbed up. Next is a little more wiring and then setup-tune. It's a possibility.
Posted on: 2013/11/18 9:15
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Magic happens... thats what the hippy bus next door says but vould be all those shrooms they found at tbe end of their garden too....
Posted on: 2013/11/18 10:42
At least the gas induction kept the oil in his sump was cleaner
Dylan cant wait to see that setup, I missed out what ecu you are using?
Posted on: 2013/11/18 11:42
i'll be there .... same car, same mods, same everything !! just a different number on the odometer ...
Posted on: 2013/11/19 9:11
From Adelaide
There's an MegasquirtII sitting on the driver side floor. It talks to the EDIS but not the Throttle bodies yet. Less typing and more tinkering!
Posted on: 2013/11/19 9:14
From Melbourne AUS
im away that weekend so i'll be missing out. take plenty of pics people
Posted on: 2013/11/19 9:55
1973 B110 A12
From Adelaide
Slight set back. I bolted everything up, purged the fuel system and set the pressure. Only one thing left to do before tuning, fill it with coolant. Wait a minute, it's running out somewhere......
Didn't take too long to figure out I'd done like many before and put the head gasket on backwards. Just a little frustrating! So now I have to pull it all down again. Looking less likely now....
Posted on: 2013/11/21 6:35
From Cheltenham
Bugger, would have been good to have seen the quad set up running
Im heading in from SE and will probs be meeting up with some Z's before hand, so if you were keen to meet up with us Zigmondo you are more then welcome too
Posted on: 2013/11/21 8:44
« 1 2 (3) 4 »
