« 1 (2)
Re: Turbo and Supercharger Myth??
Most folk here know all too well which camp I'm in.
We are all happy that your so comfortable coming out like this bart.... finally. Lucky same sex marriage is allowed in nz now.
Posted on: 2013/12/27 0:28
A small turbo or bigger turbo can be the biggest decisive factor to Lag, I dont like Lag and carefully planning, knowledge and $ is required to avoid as much of it as possible with well designed manifolding and tuning. I do like both turbo and superchargers but prefer response which is easier and looks neater with a supercharger and single SU.
I like this vid on how quickly he tunes it to run cleaner, check out the classy engine stand he uses :) - very responsive for such an old low power usually NA donk.
http://www.youtube.com/watch?v=-xmPq6azfyU
Posted on: 2013/12/27 1:17
From Sunshine Coast
Thankyou A14Force! That was the exact answer I was looking for as I knew there had to be more behind it! That makes so much sense too. Thanks for giving a detailed explanation. D, that's the next step is looking into what size turbo and plenum and runners etc for the setup. Cool video, amazing how well those 1200 and 1600 vw engines and a series engines work with turbos and superchargers!
Thanks guys problem solvered
Posted on: 2013/12/27 3:11
uldQuote:
Superchargers are typically for low down torque
Keep in mind that the most popular superchargers are high rpm, and are built like a turbo. This type is called a centrifugal supercharger. Like the old Paxtons and the modern racing bowers (Procharger and Vortech).
These have similar compressor efficiency to a turbo, so compare these to a turbo to find out how the Turbocharger makes more power. The turbo would win the race every time except where racing class rules give an artificial advantage to the supercharger.
Posted on: 2013/12/27 6:09
From Sunshine Coast
Yep I am aware of those centrifugal chargers too they would look shmick in an engine bay imo. Though I thought most of them were made for v8s that have more torque to get more out of them? Are there any smaller ones that would suit an a15?
Posted on: 2013/12/27 8:10
Centrifugal SCs arent as good as twin screw superchargers in terms of torque and overall efficiency as the centrifugal need revs to get them going so mimick a turbo somewhat without using the exhaust. Roots and Twins screw Superchargers have strong usable torque characteristics so more suited to street duty where the sweet spot is much broader from lower down.
Posted on: 2013/12/27 12:38
From Sunshine Coast
Ok yea I see it's that expansion of gas that the centrifugal misses out on. Well it's gonna either be twin screw or a turbo I think. Leaning towards a twin screw I think. I would buy yours D but I'm still not %100 sure and funds aren't their yet!
Thanks Dave
Posted on: 2013/12/27 22:09
I have different priorities, I like carbs & less wiring. I dont have a twin screw anymore Im going simple roots inefficient but can make it look old skool, I did consider turbo but prefer the instant torque. If I wanted efficient Id go efi twin charged but too much work for my simple scone.
Posted on: 2013/12/28 1:23
From Christchurch NZ
The Twin screw supercharger is the best balance. They still draw parasitic losses, but they are still very efficient.
Plus they generate less heat than a roots.
Posted on: 2013/12/29 9:35
Forced Induction!
« 1 (2)
