« 1 (2)
Re: 5 speed gearbox
From Leeton NSW
Okk so I have messaged b projects just waiting for a reply weekend1000 has emailed me a few photos of a 5 speed fitted so I can now see what needs to be done. Ill see how I go with b projects and ill let use know if I cant get a fitting kit/crossmember then ill have to give it a miss for now..yess its going into a 1200 ute.. okk mate ill check that link out what do you guys suggest is the best 5 speed to go for?
Posted on: 2014/1/15 5:12
Get in, sit down, shut up and hang on!!!
Re: 5 speed gearbox
From Fremantle, West Australia
best 5 speed?
column shift vanette wont fit
GX 5 speed is NON overdrive so it wont drag your revs down
63 box, good luck finding one!
that leaves the std shift or dogleg shift 60 boxes---both OK but I prefer std shift
Posted on: 2014/1/15 6:10
Re: 5 speed gearbox
From Nations Capital, Australia
+ with the 63, it needs more mods. Tailshaft length and a little 'massaging' the tunnel with a hammer.
Having said that, they can handle any a series
Posted on: 2014/1/15 7:27
Re: 5 speed gearbox
From Leeton NSW
Ahhk from what i read in that link there is a 56 series in a 5 speed as well as a 4 speed which im guessing is the stock 4 speed then there is a 60 series and 63 series.? Bprojects also got back to me and said they have the kit still. http://www.datsun1200.asia/category/s ... 292/pid/8884/language/en. quot
e]
Weekend1000 wrote:
best 5 speed?
Posted on: 2014/1/15 7:29
Re: 5 speed gearbox
GX 5-speed is the 56 series 5-speed. (Non-overdrive as weekend1000 has said).
Posted on: 2014/1/15 8:19
Re: 5 speed gearbox
What's the best 5-speed?
If you want performance, the GX5 gearbox is best one.
But if you want to lower highway revs, its the worst one.
If you want a tough gearbox for supercharged engine, 63 is best one.
It is whatever you want. They are all good boxes.
Posted on: 2014/1/15 8:47
Re: 5 speed gearbox
From Leeton NSW
Ok im not after performance just after another gear so it doesn't sit high in the revs at 100+km so after reading through http://datsun1200.com/modules/mediawi ... le=60-Series_Transmission .... the one that suits me best would be the 60a correct?? And so the mounting plate from b projects which I posted the link to would be all I need to fit the gearbox...thanks for all the help greatly appreciated
Posted on: 2014/1/15 11:38
« 1 (2)
