PCV Valve or Carburator Issue ?
From Sri Lanka
Hi Guys
I have problem with my B210 , It idles fine as long as i keep it's PCV Connector Closed (Yellow Arrow) (this is not my real car photo it is taken from the tech wiki), If i open it or connect it to the engine housing car suddenly dies ? what is the reason Is it related to PCV Valve or something else, can it be (PCV Valve) be cleaned and reused or need to replace it ?
thanks
regards
sumith
jpg  PCV Valve.JPG (62.06 KB)
10994_52f85582b8558.jpg 640X480 px
Posted on: 2014/2/10 4:28
Re: PCV Valve or Carburator Issue ?
From Stone Age somewhere in U.S.A.
Check for a dirty PCV valve that may be blocked open all the time. Also make sure that the hose doesn't have any crack or holes in it, causing a vacuum leak.
Posted on: 2014/2/10 15:40
From Sri Lanka
Hi Guys
I pulled that Valve on manifold out ,and i don't see it is kind of a valve it is just having a hole on it just like an adapter, is this the correct part are you referring ? or is there anything missing on it ?
thanks
regards
sumith
jpg  mf1.JPG (90.02 KB)
10994_530d86b2dfb5a.jpg 640X410 px
jpg  mf2.JPG (51.93 KB)
10994_530d86cd57fee.jpg 339X336 px
Posted on: 2014/2/26 6:16
From Snohomish, WA USA
Get a new valve. That ones shot. If I were you, I'd plug the hole on the carb and put a oil breather filter on the crank case.
Why burn crank case fumes. Your car will run better.
Posted on: 2014/2/26 7:33
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
That is missing the guts of the valve. It is now a giant vacuum leak. Plug it until upu can get a new one.
Why use the PCV valve instead of a simple filter? Two reasons are 1) it positively ventilates the crankcase, reducing varnish and sludge and 2) it keeps petroleum fumes out of the car - it smells better.
Posted on: 2014/2/26 8:31
From Central coast NSW
It also helps ur oil over the coarse of its life(between oil changes) as oil absorbs any hydrocarbons that is passed by ur rings so a positive flow through ur crank case is benificial to ur oil lubrication life as well as ur engine, if it is being sucked out then happy days but if it sit then it absorbs into ur oil reducing its friction coefficient...
Posted on: 2014/2/26 10:18
From Sri Lanka
Hi Guys
Thanks for ideas ,today i am going to find another valve
thanks
regards
sumith
Posted on: 2014/3/1 4:57
