Datsun 1200 real coil over conversion
Quite a regular
From Brisbane
Just looking for some information about how people have done conversions and what's the easiest / cheapest way.
jpg  image.jpg (117.76 KB)
17797_5366251de38fa.jpg 960X720 px
Posted on: 2014/5/4 12:31
Re: Datsun 1200 real coil over conversion
From mandurah
To be honest coilovers in the rear are pretty hard to do without chopping the foloor and stuff up and itll ride like crap
Get some air shocks , can raise and lower the car with em by increasing or decreasing the amount of pressure you put in em , and they are cheap and could match some up to bolt in
Posted on: 2014/5/5 2:01
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Easy to do. Weld reinforcements on the top bracket, then bolt the coikovers on. Remove all the the leaves except the main leaf.
Paradise Racing has rear coilovers for Datsun 1200: Part Number DATNAR $349 for non-adjustable, and DATR $499 for 12-position (soft to firm) units.
Posted on: 2014/5/5 3:57
Got a link dd
Posted on: 2014/5/5 7:27
Car free
Posted on: 2014/5/5 8:09
Quite a regular
From Brisbane
I really just want to eliminate the leaf spring entirely as they stick out from the bottom.
Does anyone have pictures of their set ups or set ups they've seen.
Posted on: 2014/5/5 11:42
From Perth
Posted on: 2014/5/5 12:26
From Narellan,Sydney
Eliminating leafs altogether means more then just a set of coil overs.you will then need eathier a 2 or 4 link setup then also some sort of pan hard bar or watts link setup.have a look thru my build thread to have a look how I did mine
Posted on: 2014/5/6 0:22
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Not too shy to talk
From Brisbane
4l link set up. Is the only way
Posted on: 2014/5/12 10:22
