(1) 2 3 4 ... 7 »
States 1200 Coupe. (Oregon, US)
From Creswell, Oregon USA
Greetings from Oregon. I bought a relative decent 72 coupe a few weeks ago.
I have build thread going on the 510 realm
http://www.the510realm.com/viewtopic.php?f=8&t=26844
I would like to share the progress here as it develops
Cheers n beers
Matt D.
www.MD-Machinist.com
Posted on: 2014/5/28 6:24
Re: States 1200 Coupe. (Oregon, US)
From MOOROODUC. Victoria
I read your write up .... what a drama getting it home.
Hope you're happy with it, there is a lot of very helpful info on this site and good people who can answer most if not all your questions.
Good luck with the build !
Posted on: 2014/5/29 2:39
I have been reading over the A to B head thread. It has to be done.... I'm going to try it out :)
I'm very happy with the car. The drama just made for good history.
Posted on: 2014/5/29 7:03
Started working on an A-Block to Mazda Head engine for the 1200.
I was able to see where the Mazda 1.5 head gasket lined up on the A-Block. Still need to go purchase a head from the local salvage yard. Guess the only salvage depot in town that has Mazda heads wants $150.00 USD. Seems a bit steep for a risk of being scrap.
Posted on: 2014/6/5 16:15
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
So inspect the head first. For $150 it ought a be good ready to run head. http://datsun1200.com/modules/mediawi ... on#Inspecting_a_used_head
Posted on: 2014/6/5 21:15
Doing some design work before I start machining my intake system for my CVK carburetors.
Posted on: 2014/7/3 8:32
Nice work. Is that a genuine Datsun 1200 base plate?
Posted on: 2014/7/3 8:42
No sir. That is much larger than the Datsun Hitachi air cleaner case.. The filter that will fit that is a K&N E-3035
Posted on: 2014/7/3 9:52
Got ya. It just looked like this Datsun twin Hitachi base plate
What's it from?
Posted on: 2014/7/3 22:01
Its a custom one.
I am milling everything but the velocity stacks on my CNC. The stacks will be printed on a Hi-Def 3D printer with a metallic plastic mixture.
I am not sure what the filter is from but I searched the Goog until I found one that met my standard for design. (20.3125" X 9.500" x 4.00")
Posted on: 2014/7/4 8:17
(1) 2 3 4 ... 7 »
