which ecu for use with ITBS ?
From mandurah
hey everone , recently sold my 40mm solex carbs in favour of a set of 36mm kiehin itbs
In the process of making a manifold , and I need to source an ecu
Been looking at megasquirt as they are cheap and do everything all the big brand ones do , but im still not sure whats the best option
Should I keep the single coil setup and go fuel only or go for multicoil and run a cas?
What would I use as a crabk angle reference? And what dozzyoptions do I have as ive been running a points dizzy as a trigger for my msd6al2
Thanks and any help would be awesome
Posted on: 2014/6/22 17:01
Re: which ecu for use with ITBS ?
Loose the distributor and the CAS
Go with MegaSquirt and a crank trigger wheel. You'll gain Fully adjustable spark curve with no distributor gear variation.
Posted on: 2014/6/22 19:53
Dont go fuel only. I have considered it as im tight byt after seeing cold start issues and other little issues on a couple of set ups not worth it now days.
Also speaking with sikyne the issues with tuning them too when other issues in the car.
Posted on: 2014/6/22 22:36
From Melbourne,Australia
Im running a megasquirt m3x in my car cant fault it so far.
Posted on: 2014/6/22 23:00
From stinking hot cairns
I'm running a megasquirt to and love it, went from an ms1 with a dizzy to a ms3pro with 4 ls1 coils. should have done coil packs in the first place as the dizzy was the week link in my set up and took up space in an already over full engine bay.
Posted on: 2014/6/22 23:38
Yep im running the same 4 ls1 coils with crank and cam triggers
Posted on: 2014/6/23 1:10
From Adelaide
I'm using mega squirt II with ITBs and an EDIS ignition. Well, I'll be using the EDIS when I get my pulley machined to fit the trigger wheel. I had an EDIS8 running off a trigger wheel in the dizzy but that wasn't reliable. Something funkey happened at around 5krpm. Seriously easy to tune the engine map with Tuner Studio (full version) and a wide band. Plug in, drive, autotune. Not expensive either. I haven't made much use of the logger license I paid for.
Posted on: 2014/6/23 9:56
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
