« 1 ... 42 43 44 (45) 46 47 48 49 »
Re: Datsun 1200 Sedan Build
From dominican republic
14x7 +1 on the front 14x6.5 +8 on the rear migth sound weird but yes wider ones up front and had to use a 5mm spacer up front. cant uses 13 inches wheels cause my brakes are the bigger ones from a turbo s13 but didnt have problems with steering arms.... im working to get a camera soon :P did a trip yesterday and came home today 7 galons of fuel and 400+ kilometers feels good but a little tight on the rear end i think i will have to remove the last leaf
Posted on: 2014/8/18 2:03
and please can you show me pictures of your 20y bar installed from everywhere damn it was hell for me to install mine and want to compare
Posted on: 2014/8/23 0:48
From Trinidad and tobago
No Problem Dude.Did you get the bar from b210 because the b310 cannot fit.Make sure u get the same u clamps an rubbers from the b210.Later on i put teflon bushings Pictures......
jpg  DSC01462-1.jpg (172.01 KB)
12526_53f7d883b7b77.jpg 1023X767 px
jpg  DSC01473.jpg (179.58 KB)
12526_53f7d8a6c7d65.jpg 767X1023 px
jpg  DSC01472.jpg (190.37 KB)
12526_53f7d8d539fc5.jpg 1023X767 px
jpg  DSC01482.jpg (104.43 KB)
12526_53f7d8ef5b6d2.jpg 1024X768 px
jpg  DSC01483.jpg (163.76 KB)
12526_53f7d901e3a1f.jpg 1024X768 px
Posted on: 2014/8/23 0:58
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
well from what i see my u clamps are different but the sway bar looks the same thank you darren :)
Posted on: 2014/8/23 3:18
From Near Bundaberg QLD
The B210 bush clamps are the same as B110/B120, but the bush rubbers are different (bigger holes for the bigger bar)
Posted on: 2014/8/26 14:20
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
i had to use b310 clamps turned arround :S
Posted on: 2014/8/28 0:08
From Snohomish, WA USA
I just removed my yesterday. Really dont need it for drag racing.
Whst i did to fit mine around the KA motor was I just cut added material and extended it forward out in front. It stuck out in front of the frame so I positioned it down before welding. That way, when the car is jacked up, the bar rises up just below the frame. Worked well.
Posted on: 2014/8/28 16:30
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Strut top plates installed.
Posted on: 2014/11/6 17:54
Street Sleeper!
I'M backk!
jpg  SAM_2415.JPG (188.22 KB)
12526_554411fd95d0c.jpg 1024X722 px
Posted on: 2015/5/2 0:53
Street Sleeper!
a trip to the sea shore?
Keep on trucking.
Posted on: 2015/5/2 1:18
