(1) 2 3 4 »
Wheel Space
From Sri Lanka
Hi Guys
I have a Problem While Fixing 165/80*13 tyre into my b210 Rear side, Look at this image
the wheel is touching the car body from Red Color Side,do you see anyhing strange here ?
i have replaced all the springs bushing etc , Have i changed the side of leaf spring ?
any suggetions ? why this cause ?
thanks
regards
sumith
jpg  wheel space.jpg (127.23 KB)
10994_544dc15ead659.jpg 640X480 px
Posted on: 2014/10/27 3:52
Re: Wheel Space
That is not good. The tyre should be centered in the wheelwell. Inspect the U-bolts attaching the spring to the axle housing. They may be damaged or loose.
Posted on: 2014/10/27 6:05
Re: Wheel Space
From Sri Lanka
Hi Guys
i Removed one side of the Leaf Spring to see whether i have fixed the front to rear side ,
i don't see any mistake like that 3 point suckle to the front and 2 pin suckle to the rear
as of this picture,
The reaason was when i jack position (Green) to attach Leaf Spring to U Bolts, rear Spring Suckle is moving Upward(to side of Red Arrow), Any body know what is the reason ?
How to Correct that issue ? Do i need to Remove my differential to correct this
thanks
regards
sumith
jpg  Leaf spring Setup.jpg (26.91 KB)
10994_545735065ef38.jpg 400X255 px
Posted on: 2014/11/3 7:55
Re: Wheel Space
From Brisbane, Australia
I assume you must have put the leaf spring in backwards. The large spring eye goes to the front.
Posted on: 2014/11/4 0:01
Re: Wheel Space
From Sri Lanka
Hi L18_B110
I also Thought that way i removed it and set it backwards then it is worse
thanks
regards
sumith
Posted on: 2014/11/4 3:41
Re: Wheel Space
then you must not have located the diff on the spring properly. The pin/bolt through the leaf spring goes into the middle of the diff's mounting plate.
or it's possible you've reversed the front spring hangers but I doubt they'd be offset enough to move the wheel that far back.
Posted on: 2014/11/4 5:23
Re: Wheel Space
Can you remove the wheel, then take photos of the spring & spring mounts?
Posted on: 2014/11/9 1:09
Re: Wheel Space
From sydney australia
It looks as if the locating bolt that the spring perch sits on might be too small or not there. This is the bolt that holds the spring pack together, & the diff housing should sit on top of it. If you don't get it on, the diff will slid backwards & forwards with each application of brake or accelorator.
Posted on: 2014/11/9 2:10
Re: Wheel Space
From Sri Lanka
Hi Guys
Here are some snaps taken out , look at the Spring Moved Back image when i jack up the spring
Spring Eey Moves Back , even if i put it with the suckle it self it is going backward up like this
so the wheel position comes to the rear side more ,
any body can give me lenght of Leafsprings exactly ?
thanks
regards
sumith
jpg  front side.jpg (126.37 KB)
10994_546442d974ce4.jpg 640X480 px
jpg  Rear side.jpg (152.26 KB)
10994_546442eeb0c3a.jpg 640X480 px
jpg  rear suckle.jpg (165.20 KB)
10994_54644303ced3f.jpg 640X480 px
jpg  Spring Moved back when jack it up(without Sucle).jpg (158.54 KB)
10994_5464432415f56.jpg 640X480 px
jpg  wheel position.jpg (151.02 KB)
10994_5464433f3125c.jpg 640X480 px
jpg  whole set.jpg (152.34 KB)
10994_54644352a24e4.jpg 640X480 px
Posted on: 2014/11/13 5:39
Re: Wheel Space
B210 leaf spring is 1165 mm long.
6-leaf spring pack is from a commercial vehicle or older car. Sedan should only have 4 leafs. Does the other side match it?
Posted on: 2014/11/13 7:17
(1) 2 3 4 »
