« 1 (2) 3 4 »
Re: Wheel Space
From Sri Lanka
Hi DD
Yes Both Sides have similer no of spring , I will check the Lenght of them , I had the same set earlier too i used it without any issue , There was a one broken leaf so i replaced it, but it was not the main leaf too
thanks
regards
sumith
Posted on: 2014/11/13 9:09
Re: Wheel Space
Is it possible that the front 3bolt spring hanger is offset and has been fitted from the wrong side? My nuts are on the inside not outside like your pictures, just a thought
Posted on: 2014/11/13 9:51
Car free
Re: Wheel Space
From Melbourne, Aus.
From the picture you have with the shackle missing and the spring mount against the chassis it appears the spring is to long. That mount should be closer to that position when the spring pack is almost flat not when it's not holding the weight of the car. It looks like if you had the shackle in and compressed the spring the shackle would actually fight against the spring when extends its length during compression.
On all my datsuns the rear shackle is almost vertical and is not far past lining up with the chassis mount and they all sit with the springs not far from flat with the weight of the car resting on them.
It would be my guess that they are not the springs for that car.
Posted on: 2014/11/13 11:25
Re: Wheel Space
From Sri Lanka
Hi guys
i checked the length of leaf those are similar to what dd said also if i reshape them will that be ok ? i don't know what to check any more
thanks
regards
sumith
Posted on: 2014/11/22 15:02
Re: Wheel Space
From Sri Lanka
Hi Guys
I pulled the Leaf and checked the verticle space between(please check the attached Sample this is not the real image ) leaf top and center bolt it is just 2mm below to 8 inches, how about that ? , if i increase that will that be a solution ? when it is fixed to the car with car weight it is almost closer to horizontal
jpg  leaf ver.jpg (126.20 KB)
10994_5471e5c941222.jpg 640X391 px
Posted on: 2014/11/23 13:49
Re: Wheel Space
From Brisbane, Australia
no, increasing the camber or arch of the springs wil not fix it. Al that wil do is raise the car up higher - the spring will still be all wrong for the car. Get a pair of 120Y springs from a wrecker, or get a new main leaf made up the correct length.
Posted on: 2014/11/24 0:04
Re: Wheel Space
From Sri Lanka
Hi Guys
Can any Body Tell me what is the Length from Front Leaf eye to center bolt,and rear leaf eye to center bolt ? This is for my 1974 b210
thanks
regards
sumith
Posted on: 2014/11/27 10:24
Re: Wheel Space
B210 leaf spring is 1165 mm length
Posted on: 2014/11/27 21:10
Re: Wheel Space
I'll measure mine for you when I get home.
Posted on: 2014/11/27 22:52
Re: Wheel Space
These are the numbers I get measuring along the underside of the spring with the tape measure end hooked over the center bolt:
530mm center bolt to middle of front eye
650mm center bolt to middle of rear leaf eye
That adds up to a bit longer than the listed spec because the tape measure is hooked over the center bolt and the tape could not be right against the spring because of the base plate. Plus the error in judging the center of the spring eyes. But it's close enough for these purposes.
Posted on: 2014/11/29 22:42
« 1 (2) 3 4 »
