I should say wider track through negative offset wheels (or spacers).
My old 1200 coupe handled pretty well and won its class almost everywhere it went
But after fitting the flares and negative offset wheels, it developed a problem at Morgan Park which was the main place I raced back then. Through the fast esses at the back of the track, the fast line through there was to ride one of the kerbs with a slight dab of brakes before the the tighter RH turn at the end of the esses. Never a problem in the previous 3 years I'd been running there, but now all of a sudden it wanted to rip the wheel out of my hands if I braked with a wheel on that ripple strip! It didn't seem to be a problem at Mt Cotton or anywhere else I raced. Changing the line through the esses was slower. I knew it was costing me time, so as much as I liked the way it looked with those new fat 13x7 -7 Superlites, I changed to 14x7 +3 hotwires with a slightly taller 195/60 and the problem was gone.
Both sets of wheels had the same A032R tyres, but it now had criper turn-in and better mid corner grip as well, and was 2.6sec faster over a 3 lap supersprint (they only supplied total times, not individual lap times).
The reason is scrub radius - the distance between where SAI (Steering Axis Inclination) insects the ground and the center of the tyre's contact patch. SAi is a line drawn throught the center of the top strut mount and the balljoint pivot down to the ground. Scrub radius is positive if the tyre center is outside that SAI intersection with the ground and negative if the tyre center is inside the SAI line. Struts don't like too much '+' scrub. It makes them unstable under brakes on uneven ground, and also reduces the amount of cornering power that can be generated.
On that car the problem was also helped along by the Stanza struts with the hub face further from the balljoint, which required a more positive offset wheel to keep scrub radius acceptable.
