Browsing this Thread:   3 Anonymous Users
« 1 ... 50 51 52 (53) 54 »
Re: Leveys 2dr sedan v1.2
From Sydney
Nigel,
How do you find the throttle linkage. Does it maintain the balance between the carbs? I got frustrated with a similar setup on my engine and ended up going with a magard setup. I looked up a similar linkage type on fleabay suitable for dellortos.
dellorto linkage for twin carbs
Posted on: 2015/2/14 1:13
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Perth WA AUS
Not sure yet benny, I had the carbs balanced a while ago but need to check them again.
Once I hit the power band it pulls hard regardless so it hard for me to tell.
Posted on: 2015/2/14 8:08
Datsun 1200 2Dr sedan.
Hi Nigel,
Have a look at the standard system on an old Alfa with DHLA dellortos. Makes balancing the carbs simple. Set and forget. Most of the kits with twin actuating rods have lots of freeplay points in them and are frustrating to get right and impossible to keep right. There is plenty of junk out there. The best and most simple cable actuation system is fitted to a 70's Escort Twin cam. The end of the inner cable is fixed and the outer cable actuates the throttle lever arm. Very simple & very clever.
Link to the balance part of the system here:
http://www.ebay.co.uk/itm/WEBER-DCOE- ... 23414b5541#ht_2462wt_1266
Posted on: 2015/2/17 9:26
From Perth WA AUS
That looks like the best setup Larry, I might see how mine goes after the next tune as i have checked it and there is no real play in this setup yet.
Thanks for the link I might need it in the future.
Posted on: 2015/2/18 7:27
From mandurah
Looks pretty shmick nige!
Where did you get the gilmor kit and the filters? Need a set of decent filters are stacks for mine , redline ones shade apart haha
Posted on: 2015/2/18 19:10
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth WA AUS
Hi Jess,
Gilmer kit is from kemotorsports online.
Ram tubes $54 old stock from Holley parts bassendean filters from them aswell part # AFM4563 @ $59/pair.
Holly parts: 9378 2121
Posted on: 2015/2/19 6:47
From mandurah
Thanks nige ! Was the gilmor an a series kit or did you mod a chev one to fit?
Cant wait to get my car back together! ! Hoping to have it painted in a week or 2!
Posted on: 2015/2/19 19:43
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Perth WA AUS
Its the a series kit, I am pulling mine off the car soon to quieten it down a bit. buy mine if you want.
Posted on: 2015/2/20 13:41
From Perth WA AUS
a pic for BigD:
jpg  20150306_160434.jpg (155.72 KB)
9665_54f969a388ad2.jpg 826X465 px
Posted on: 2015/3/6 8:47
Ill give you 15k for your car Levs :)
Posted on: 2015/3/6 12:22
