Browsing this Thread:   3 Anonymous Users
« 1 (2) 3 4 5 ... 49 »
Re: Turbo EFI A12 for under $1200.
Posted on: 2015/3/12 1:16
From Melbourne Vic
Is that a link to a thread that has a link to another thread that happens to be this thread?
your hairbrain ideas simon have many followers!
Posted on: 2015/3/12 3:23
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Ballarat Victoria
Thanks for the lend of the sacrificial car Lags!
To answer a few Q's..
It's going to use a MS1 ECU at this stage.
It will be using a 4 tooth trigger in the distributor and no crank trigger.
It will probably be a 4-6 week project.
This can be the "discussion thread" and I'll do another titled "Build thread" hopefully without any comments to keep it easy for others to follow.
Posted on: 2015/3/12 4:45
VIC DYNO HIRE
From Melbourne, Australia
sounds great!
will it run a 13? (this thread reminds me of "13 seconds for $1300")
except this one is more believable
if you can get it done for $1200 i will be impressed, the additional labor required to keep costs down is going to mean this is still a mammoth task for the average car builder though
Posted on: 2015/3/12 5:12
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
It's going to be as simple as I can make it. With the least amount of work for each stage. Also only buying what is absolutely necessary.
Its about the best I can do.
For example, the Inlet manifold should take less than 2 hours to make. Including, making fuel rail, injector bosses, press reg mount and throttle body/cable. It will cost less than $150 inc new inj.
A 13?....Probably not
Posted on: 2015/3/12 11:35
VIC DYNO HIRE
From Creswell, Oregon USA
So you doing a single intake TB? I was going ITB's but will hold off until I see how this goes.
Great thread and loved your Coupe thread too.
I have gathered so far for my setup and hope to stay along your guide.
250cc injectors-$50.00
TPS-$10.00
CAS-$80.00
Posted on: 2015/3/12 14:51
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
From Adelaide, Australia
Can't wait. I'm in the middle of mine atm and with 4 kids budget sounds good :p.
Posted on: 2015/3/12 17:48
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
Re: Turbo EFI A12 for under $1200. Discussion thread
OK... I'll try to do a bit of a build blog so others can copy if they want.
I'll start a new thread without comments or questions to keep it clean! Any Questions or suggestions, please post them here. I can edit the build thread as required.
Just remember this is a budget build to minimizes outlay and time involved to get a reasonable result...Hopefully!
Step One: building the EFI manifold
You will need:
-Throttle body from Hyundai Exel X3 SOC engine
-Standard A12 inlet manifold and Carb
-Fuel pressure regulator from (97 Toyota Corolla or 97 Mitubishi lancer)
-3-5 mm Ally plate to make adaptor.
-1 large fuel injector(1000cc for petrol or 1300+cc for E85)
Posted on: 2015/3/17 3:38
Edited by sikyne on 2015/3/17 3:59:16
VIC DYNO HIRE
Put a link of discussion thread in the build thread simon If possible.
Nice and cheap easy single point set up.
Don't ea falcons have single point that matches a 32/36 manifold adaptor too from memory?
With a stock carby filter top no one would know it's efi almost. I like a lot
Posted on: 2015/3/17 4:45
From Central coast NSW
Unfamilia, sounds like u could have a build thread of ur own 😉
Posted on: 2015/3/17 6:54
