(1) 2 3 4 »
Engineering 120y a14 turbo? PLEASE HELP! Now with Pics!
From Penrith, Sydney, NSW
I am thinking about buying a 120y coupe that has an A14 blow through turbo in it. Completely stock otherwise including wheels, brakes, diff etc. I was just wondering if anyone has any idea what issues i might run into when getting it engineered in NSW? Never had to engineer a car before and dont want to bother if its going to be too much effort or $$$. Apparently it was engineered in SA. Any help or opinions would be great.
Thanks
Trav
Posted on: 2015/5/9 6:54
Edited by Trav on 2015/5/13 11:24:42
"If the doors of perception were cleansed, every thing would appear to man as it is......infinite"
Re: Engineering 120y a14 turbo????? PLEASE HELP!
Ask the seller if it is certified in SA, and to provide the certification details. If it meets nationwide VSB6 or VSB14, according to the RMS website it can be certified in NSW.
If your vehicle complies with the standards explained in Vehicle Standards Bulletin 6 or Vehicle Standards Bulletin 14, you can be confident that it complies with applicable vehicle standards, pending certification.
Posted on: 2015/5/9 7:23
Once again dave you come to the rescue. Thanks.
I just went and checked it out and its not a bad little car. I just need to decide whether its gonna be worth the $ to get it on the road. I think i might just pull the turbo setup off and put a weber on it instead then i dont need to engineer it. Its got a leaky diff which im gonna have to fix or replace.
Actually dave do you know what diff is in a australian delivered 74 120y coupe? Is it h145, h150 or borgwarner? Cheers.
Trav
Posted on: 2015/5/10 3:58
Japan-built 1974 came with H145.
Posted on: 2015/5/10 7:11
Ah no wonder its stuffed then. Well i think that makes up my mind for me. Definately gonna take turbo setup off.
Trav
Posted on: 2015/5/10 7:25
Edited by Trav on 2015/5/10 7:47:26
Change of heart again after getting it delivered today and giving it a bash. TURBO MUST STAY!!! LOL
Anyone else had experience engineering a series turbo? What other upgrades do you think i might be looking at needing to do to pass?
Thanks
Trav
Posted on: 2015/5/12 9:26
Also i have been reading through past threads dave and there are conflicting reports on what diff came stock in 74 120y, some even from yourself stating they were H150. Whats the easiest way to id my diff to find out? Is h150 bolt in like h165 or studs same as h145?
Thanks
Trav
Posted on: 2015/5/12 12:58
Edited by Trav on 2015/5/12 13:21:22
trav pics pls, just for the library and the pervs we are here!
Posted on: 2015/5/12 13:21
1974 is H145
1975-1978 is H150
Exception: Australian assembled (meaning sedan) is BW68
Posted on: 2015/5/12 19:59
From Brisbane, Australia
engineering a turbo conversion under NCOP requires a full emissions test. It will be all but impossible to pass that with a carby.
Posted on: 2015/5/13 0:25
(1) 2 3 4 »
