« 1 2 (3)
Re: T50 5-speed for Datsun 1200
Sorry I thought I answered your questions before you asked them 3 posts ago!
D,
You haven't answered the questions im asking you mate.Im simply asking for you to elaborate why one gearbox is superior to another by stating facts backed up by results and data.Not about experiences as different people have different experiences with all types of gearboxes.Too many variable factors i.e gear fluid used,condition of gearbox,driving style etc etc
and as ddgonzal stated, its all relative.So lets just talk about the gearboxes in question.
How many cars you and your friends have driven don't change any attributes to gearboxes were comparing!!
Its irrelevant information...My 56 a 4speed shifting smoother than my brothers close ratio t50 behind his worked k-series is irrelavant and the reason why i never even mentioned it in the first place.
so lets keep it simple and factual.Even better if we can both provide verifiable links to back up our discussion.
I.e For perfomance benefits,
Gearbox a is better than gearbox b because it has better gear ratios,
gearbox a is better than gearbox b because its lighter in weight
Gearbox a is a true direct fifth 5 speed , gearbox b is a 4 speed with an overdrive gear
Gearbox a is a bolt on,Gearbox b isn't
etc etc etc
Being popular and affordable has nothing to do with comparing performance gains.Esp not if your planning on getting a custom gearset for the T50.
Data and facts!!This is the type of information i was after,
So explain as to why a "STOCK" T50 gearbox is "SUPERIOR" or would perform better than a F5C56A behind an 1200-1300 A-series.Facts,links,sources...
Lets discuss about their attributes rather than irrelevant information.
Now to elaborate further - I sold my close ratio 56a which was fully recoed and after a year behind an A16 2nd started to crunch, new straight cut gears were used on 1st and 2nd after its last rebuild and stripped 2nd gear gearing down from 4th and 3rd at calder. I treated that engine like my previous R100 bridgeport but I treat all gear changes with upmost respect. The T50 I used no cluth on was due to a broken clutch cable on the way home from a cruise, now I had the same issue on a fresh 60L and ruined that box behind a highly strung A14 I just acquired from a deceased estate with all work done by ex-nissan race mechanic Gordon Dobey a works datsun 1000 mechanic in the 60s when they won at bathurst. The strength of datsun 56 and 60 series boxes is similar to suzuki boxes they wear quickly after 200k.
Toyota knows gearboxes better than Nissan always has and even "used" or copy Porsche knowhow for the better German synchros as the Japs could not duplicate the same quality or design for them. Toyota also went to Yamaha to design better heads, Nissan studied other makes. Japanese have always copied and gone from there.
I will ask specific questions to avoid misunderstanding each other.Hopefully i get specific answers.
Now the 56a close ratio you were refering to,
was it a F5C56A or the 56a 4 speed close ratio?
Nismo competition purposely built and recommended the F5C56A for 1270cc-1300cc engines! Why someone would spend that kind of money and put them behind an A16 makes no sense,atleast to me anyway.There is a reason products have recommendations.From brake fluids to performace parts.
Can you also elaborate how you went about putting straight cut gears to the first 2 gears of your gearbox?
For competition, rarely do you get to use the first gear unless in rally.Doesn't make any sense why instead of gear 2,3,4 and 5 which are mostly used in racing ,one would straight cut the first gear which will be least used if used at all,straight cut the 2nd and then leave 3rd,4th and 5th gear.What would be the purpose of doing that to the first gear?
cheers
Posted on: 2015/5/15 7:57
The facts are pretty simple you asked what gearboxes I had twice and you ignored my previous post or skipped it.
Do you want to compare my ex Nismo F5C56A opt 2 to a T50 stocky? You have to understand what an opt 2 commands these days and also Gordon Dobey who I mentioned earlier knew of these boxes inside out as he serviced them for the Nissan racing team locally and abroad.
I got the box from one of his clients and had no idea of their worth in those days just bought the car as deceased estate. Yet Gordon preferred to use the T50 himself for local racing for the same reasons Ive mentioned earlier.
You then say my experience has no bearing cause you and your brother have 2 boxes to compare? then why ask me what I had? which I answered already. You get a good 56a 4 speed and its only comparable to a toyota K40. You are talking chalk and cheese by comparing your 4 speed vs been around australia driven by every OZ teen bogon corolla box. Just using one example proves nothing you are right there however it is comical to think you praise your box so highly.
Since we are talking about 5 speeds, why on earth are you asking if I had a 4 speed close ratio box?! you need to read again we are talking 5 speeds, no offence but you are getting ridiculous in even asking and going over the same slate. I would not bother with a nismo 4 speed unless it had gearing that even Nismo didnt supply. You have to be more specific if you want some data or robotic answer to suit whatever its is you dont want to comprehend.
Also I dont need any history about Nismo or fanboy web data just the facts and experience shows clearly Nissan did not make the datsun box as quality and abundant as toyota has specifically the T series box for their A, K, T, 4age, R, S and other engines.
Take a look at the workings of a T50, the finish on the casting, the synchros sizing and every part of the T50 says quality. The Nissan just pumped them out and hoped owners didnt do skids with them.
My drama in the past with the t50 was the first gear choice and close ratios choices available seemed too expensive but Ive found fully optioned t50s for around the 2500aud mark and also a complete gearset from Argentina is possible for 1000usd.
If you can get yourself something like my old boxes and have the T50s to compare them on the road which is where most of our datsun spend time on you would have a different idea of quality.
Now if you want to be more pedantically stuck with Nissan are the best for every A series just ask other members what they think here of the datsun 5 speed boxes vs the t50 for track and rallye. Get more than a couple opinions. Try RC and some racers up north that use the T50 instead of often needs rebuilding datsun 56 and 60 series boxes.
I said it earlier if you prefer and are able to get the original gear in good condition go for it, I and other prefer the non original T50 behind an A.
Some prefer the 71b behind their boosted As and even that particular setup had issues using a quality 71 factory close ratio Z box!
Even here with my local Jp nationals the knowlege is clear that datsun boxes to Toyota are what suzuki boxes are to Honda.
My opt 2 CR box had a 2.67 first gear, so please do some more research and try to see that even that gear ratio is required for a good take off almost anywhere with a highly strung A series road or track.
Posted on: 2015/5/15 9:09
From melbourne
fair price but T50 Race box in NZ didnt sell
jpg  Screenshot_193.jpg (55.56 KB)
14887_5555aef70baf1.jpg 842X360 px
jpg  Screenshot_194.jpg (101.12 KB)
14887_5555af0912199.jpg 846X361 px
Posted on: 2015/5/15 9:33
From Sydney NSW
Nissans are not revered for their quality.
Nismo were probably recommended as racing class may have been restricted.
Posted on: 2015/5/15 10:02
« 1 2 (3)
