HAALLPP with valve clearances
Hey guys.
I have everything in the bottom end of my A15 good to go.. I've just put the head on and I am doing the valve clearances..... I'm just wondering how I can tell when the motor is at TDC of the CORRECT stroke ( If even necessary )... I know where TDC is on the dizzy.. But unsure of which rotation it's on....
And then which order I do the actual valve spacing.
Cheers :)
Posted on: 2015/6/20 19:48
Re: HAALLPP with valve clearances
Turn the crank to TDC, then remove the distributor cap. If its pointing to #1, you are done. If its pointing to #4 turn the crank one revolution.
Posted on: 2015/6/20 21:38
From Beautiful Sunny (sic) Melbourne
what I've always done with a 4 cylinder engine is turn it over until the valves on cylinder 1 are "rocking' - which means one is closing and the other opening. If you move the crank forwards and backwards at that point you see the two valves "rocking" and that means you can do the valve adjustment on cylinder 4. Then do the other cylinders accordingly:
4 rocking - adjust 1
3 rocking - adjust 2
2 rocking - adjust 3
Posted on: 2015/6/21 5:31
From NZ
For 4 cylinder engines I reckon the "rule of 9" is simplest. ie :
Valve 1 fully open - adjust valve 8 (1+8=9);
Valve 2 open - adj 7
And so on
Posted on: 2015/6/21 13:41
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
* TDC #1 - adjust valves 1, 2, 3 & 5
* TDC #4 - adjust valves 4 & 6, 7, 8
counting from front of engine ... see Valve adjustment
Adjust when cold. Make sure that a 0.13" feeler gauge fits, and a 0.14" gauge does not fit.
jpg  enginealmostdone1318.jpg (187.11 KB)
174_558725cbc8fee.jpg 1280X960 px
Posted on: 2015/6/21 21:30
Edited by ddgonzal on 2015/6/21 21:59:55
