120y axles
From gold coast QLD.
Hi all,looks like i may be in the market for a pair of 120y axles(jap)not borg warner,not 100% sure yet will know very soon let me know what you have,may consider complete banjo.Gold Coast/brisbane Cheers
Posted on: 2015/6/24 9:23
Re: 120y axles
From Sydney
Hi Bert, I have a matched pair under the house, backing plates, bearings and retaining collar. Out of a H145 housing. Free to you, just sort out the shipping. I'll send a PM.
Cheers
Posted on: 2015/6/24 11:38
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: 120y axles
B210 and B110 are the same. H145 or H150 use the same axle and brakes. The bearing differs for the B210, so if you use a 1200 axle, the bearing must be changed.
Posted on: 2015/6/24 20:06
Re: 120y axles
From Brisbane, Australia
Bert, I've got a good complete drum to drum 120Y H150 lying around and tailshaft you can have with it. $30 for a case of beer and it's yours. Northside Bris @ Strathpine
Posted on: 2015/6/24 23:24
Re: 120y axles
Thanks Harry,I'll own that.PM me your number and i'll call and organise a pick up.
Cheers Rob
Posted on: 2015/6/25 7:14
Re: 120y axles
From Townsville, Qld
You know what tick me off about 120y axles is the spline size, the shaft is as thick as the 165 axles but then they're tapered down for that piddly 150 spline.
Posted on: 2015/6/26 5:04
Re: 120y axles
That's good isn't it? They are stronger than needed for the intended job, yet lightweight for extra performance.
Posted on: 2015/6/26 5:38
