compression
From sutho shire
hay guys im interested in turboing my 180b for fun just a suck through set up with SU carby T25 of my ca18det and custom manifold i made up wet day at work,
the question is i wanna run about 10psi how do i do about with lowering the compression of the motor? i have a copper head gasket for L18, should i run 2 head gaskets?
any advise in lowering compression would be great
cheers andrew
Posted on: 2004/6/10 9:31
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Re: compression
From Sydney
i love 180bs, i used to own a slammed one with half cage, twin SU's, locked R180, buckets, fender mirrors etc etc. i miss it so much now. haha anyway just run standard compression, L18s will withstand anything.
Posted on: 2004/6/10 13:23
Street Tail Dancers
1200 coupe - A14
Re: compression
From Brisbane, Australia
2 headgaskets does not work. you could get a open chamber head off a L20 motor (U67 I think)
Posted on: 2004/6/11 2:04
Re: compression
From Christchurch NZ
Mill out the combustion chambers??
Maybe get a scrap head , and butcher it to see how far you can go. Or maybe try and see if anyone makes a decompression shim for under the head.
Posted on: 2004/6/11 5:53
Forced Induction!
Re: compression
Quite a regular
From Windsor NSW
The most common way for lowering compression for the L18 from what i have heard is putting the L20 head on it. It is the most easiest way that i have heard of but sorry i am not sure as to what compression it will give you. I suggest you contact Barry from Datsport. They are located in Lonsdale in South Australia, (08) 81862100. This guy knows heaps on datos and he used to rally them and won the rally of S.A years ago. The current thing these guys are doing is SR20DET conversions in 1600's. Previous to that they made supercharger conversions for the L series so they would definately know ideas on how to lower compression for your car.
Heres there web site:http://www.datsport.com
Posted on: 2004/6/11 7:59
Re: compression
From sutho shire
cheers guys for the info i have spoken 2 my mechanic and he said that they make head savers, which is like a metal plate that raises the head, with copper head gasket should be sweet,
so i am gona do this and give u guys a update with a few shots, wont be finished till next weeknd as i havent got plate yet,
cheers andrew
Posted on: 2004/6/12 7:21
Team New skool
