Why wont my indicaters self cancel
From Christchurch NZ
The blinkers on my 1200 ute dont self cancel. I've had the wheel off , but I didn't figure out which bit is faulty. Which bit do I need to replace???
Is it the corner bits on the mechanisim that wear down? should I try tweaking the prongs on the wheel out just a smidge?
Someone here must know, so i'm all ears.
Posted on: 2004/6/11 6:08
Forced Induction!
Re: Why wont my indicaters self cancel
From Canberra, Australia
the little nodules that click the indicator off as you turn. get some shrink wrap and shrink wrap over them...
HAve you got an aftermarket steering wheel?
Posted on: 2004/6/11 6:14
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Not yet, but I will soon. So the corners wear down?
Posted on: 2004/6/11 6:37
Forced Induction!
From Christchurch. NZ
well you could let me have a look, I won't charge you, honest
Posted on: 2004/6/11 9:11
From Perth, Australia
when you take of the wheel there is a little metal "M" shaped thing on the left hand side. This is bent so that every time the wheel lug thingys make contact they push down and cancel the indicators. try bending it again ever so slightly cause from my experiences they are a bit brittle. sorry for the lack of technical term but hey im not wheel fixy guy.
Posted on: 2004/6/11 9:21
Datto 1200 ute undergoing rebuild... one day it will be finished. i hope. *FINISHED*
From Perth Western Australia
I had the same problem in my car a while back. can't quite remember how i fixed it, but it was just an ajustmet thing. (i think the little leaver thingy just needed to be slid up the column a bit.... no i'm not a the technical type either)
Posted on: 2004/6/11 10:28
did you bothe use the thingy ma jig that bends the douvalacky to make the whatsit work again
just fiddle with the wire thing on the left till it works again, this usually happens when you take the wheel on or off many times or fit an aftert market one
Posted on: 2004/6/12 4:18
thingy ma jig
douvalacky
Love the terms!!!
Posted on: 2004/6/12 4:22
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
ps... if your in nz, just add bro or cuz to make the translation. baaaaaaaaaaaaa
Posted on: 2004/6/12 4:29
really??? trueeeeeeee broooooooo or sholud that be cuzzzzzzzzzzz???????
Posted on: 2004/6/12 5:51
