A12grunt Daily coupe Build
Il try and update this thread whenever possible.
I've been looking for another coupe to use as a daily for a while now.Something "rough".
Been too busy this year.
Will start working on it and my other coupe next year after the festive season.
some pics.
jpg  SSR mk2.jpg (179.24 KB)
15239_5677f8cdd2112.jpg 1000X561 px
jpg  SSR mk1.jpg (173.57 KB)
15239_5677f8e0803d3.jpg 1000X562 px
jpg  DSC_0036.jpg (177.88 KB)
15239_5677f95d0775e.jpg 800X450 px
Posted on: 2015/12/21 13:06
Re: A12grunt Daily coupe Build
From Christchurch NZ
What an awesome daily! Looking forward to seeing small updates
Posted on: 2015/12/21 19:19
score!!
Posted on: 2015/12/23 5:31
thanks for the compliment guys
D,
Will be a while before i come across some tomei 79mm pistons to build up the spare a15.
What other options could i use for 79mm cast pistons for a15? Prefarably with "valves cuts" on their tops.Perhaps something that won't need changing the rods.
And where can i get a-series work done in melb?id prefer guys who have dealt with a-series engines. i.e boring etc
Also where can i source 40intake and 33exhaust valves locally?any cheap way to do so?
Cheers
Posted on: 2015/12/23 8:30
also fronts are using supafatto 120y coilovers.very recommended, just incase anyone is looking for a light weight coilover setup.
Car rides very smooth.
Posted on: 2015/12/23 8:52
peterzekert.com. Or use Justy pistons. Or Mazda pistons
Posted on: 2015/12/23 8:53
DDgonzal,
do the mazda and justy pistons require any modifications to the rods?
I checked pjz website and his got mostly forged pistons.Im after cast pistons.
Posted on: 2015/12/23 8:56
Justy swap is the old-time swap. It uses stock rods. The problem is they are expensive new. If you can find two sets of used justy pistons, it might be cheap
Posted on: 2015/12/23 9:25
From Mordialloc Victoria 3195
BNB Engines in Westall road has a guy in there that has built A series race engines.
They did a nice job on a re-sleave and full re-machine/balance on mine
Posted on: 2015/12/24 11:42
keep it simple
Quite a regular
From Sydney
A daily and still an A-series. Love it. Do you plan on upping the security at all?
Posted on: 2015/12/24 22:49
