« 1 2 3 4 (5)
Re: Flywheel bolts failure\fix\questions
Thanks Rusty for this site link
http://www.dansmc.com/torque_chart.htm
its saved me a bundle with Suzuki bits I needed as Suzi charge more than a wounded elephant for the same items.
My Uncles solution pretty much solved all issues with flywheel bolts from A to Z series.
For the A I followed his advise after researching the qualities of Loctite 266 and to mark with chalk the old bolts and then torque them back on the flywheel leaving space for one of the new ones each time, this prevents the Loctite getting in between the flywheel and crank which can prevent proper torque readings.
For extra strength I noticed that only the A10 comes with 3 black carbon steel secure locking tabs for each pair of flywheel bolts to stop them coming loose (I havent noticed this for A12/14/15 I played with as never got a virgin one) yet used the same tabs on them in most cases.
These tabs with the Loctite 266 at 10psi higher than the recommended 65psi from factory has been very effective even with an idiot who bought one of my old B10s and revved it like a motorbike as he wanted to blow it up by taking it to 10k rpm all the time. Eventually a valve hit the pistons and it chewed itself up but flywheel bolts where still hard to remove until I heated them up a tad.
Never overtighten the factory rod bolts as you will get unlucky as they do stretch as Rusty has stated.
If possible clean up your flywheel and crank surface contact area really well so it has nothing but clean steel! if time permits spend a little time and money to get the flywheel rebalanced to make sure your rebuild gets the best possible chance of lasting for years of abuse :)
Posted on: 2012/2/14 3:14
From Townsville, Qld
everything that's going back in that motor is getting balanced, another mistake I let happen by not hearing the full story
Posted on: 2012/2/14 10:41
So I was looking for something else in the search bar and this came up instead, so might as well give you all an update.
Lemonhead's crank was a real blessing and Bondi doweled it to another lightened A12 flywheel. We ended up modifying Opel Astra flywheel bolts to use (3 of them have the heads shaved down a socket size, loctited and torqued up tight. Rotating assembly was balanced.
It's been pretty good for the last few years but as I stretch out a serice interval I've noticed the clutch has a vibration around 3000rpm that goes away when you spin it faster. Should I give the clutch and flywheel a check over when I swap this whiney 56 series box out?
Posted on: 2016/1/9 3:44
Good to hear that balancing the engine and loctite/doweling the flywheel is the go
What are the clutch vibration symptoms? For example does it only do it with the clutch pedal down? Does it do it on the road, or when revving in neutral?
Posted on: 2016/1/9 3:58
will check if it does it in nuetral but I've only noticed it when I just take up the slack on my clutch pedel, so not really engaging the clutch just under load down around 3k or so. When you get to 4k+ it's silky smoooooooove
Posted on: 2016/1/9 5:41
It only happens when you put your foot down on the pedal to take up the slack -- that's when the throwout bearing contacts the clutch cover.
so the fingers on the cover may be worn unevenly. Not a problem if you don't notice while driving
Posted on: 2016/1/9 5:53
« 1 2 3 4 (5)
